Drag Racing Tech - A/c delete plate, can you retain heat?
nastyiroc
06-09-2012, 03:15 PM
CAN HEAT BE RETAINED WITH USE OF THIS PLATE?
http://www.bmrsuspension.com/index.cfm?page=products&vehicleid=6&maincatid=56&catid=148&productid=247
96LT1355Z28
06-09-2012, 05:31 PM
Yes but you will have to modify that pannel. It will have to bolt to the engine bay side and you will have to cut out the holes for the heater hoses. There's a few theads out there with pics on how people have retained heat while deleting the AC.
1nastyss
06-10-2012, 05:31 AM
I'm running the same plate and did like he said, bolted it up from the engine bay side, cut the 2 holes out for the hoses, don't forget to drill the smaller hole for the vacuum hose to use the controls
Orange99Z
06-10-2012, 07:28 AM
http://www.ls1tech.com/forums/drag-racing-tech/1054626-c-delete.html
http://ls1tech.com/forums/drag-racing-tech/1345603-drop-15lbs-off-your-heat-still-keep.html
99french
06-10-2012, 05:12 PM
Yes u can with that bmr plate. Drill it out for hoses. I used the summit heater. Wired it into my stock fan control too.
studderin
06-10-2012, 05:28 PM
I made a lighter heater with the stock parts. simple, no duct or big parts, cheap, everything you already have.
info in my build thread
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
