Generation IV External Engine - double roller timing cover
1sikrs
06-09-2012, 09:23 PM
Can anyone tell me if anyone makes a new timing coverfor the double roller timings set??? What is everyone running if u have a double roller
For my 2010 camaro ss ls3 has a code PO341 so I'm thinking the sensor is to close
lazaris
06-10-2012, 08:22 AM
Comp Cams is due to come out with their new front cover this week. It allows for double rollers and high volume pumps without modification.
http://www.youtube.com/watch?v=zXOp5zLw6hs
http://www.jegs.com/i/Comp-Cams/249/5496/10002/-1
DietCoke
06-10-2012, 08:48 AM
I dont have an issue with mine. Get out the dremel.
+badss+
06-10-2012, 10:45 AM
They machined my front cover. I'm sure the comp one will be over priced compared to using a dremel on it
+badss+
06-11-2012, 11:05 PM
hmm wonder how those new rocker arms will work on a ls1 engine.. i know off topic sorry.
lazaris
06-11-2012, 11:30 PM
Depends what your looking for.
2win_SS
06-12-2012, 12:01 AM
I'm sure this would be considered gen 5.... Might get more help there
+badss+
06-12-2012, 12:06 AM
Well its for all ls engine's, It has the sensor part built in for DoD but will still work for a ls1,2,lq4/9 and so on that's what I got from the video
+badss+
06-12-2012, 12:08 AM
also depends if OP is keeping the dod or deletes it.
lazaris
06-12-2012, 11:55 AM
Or if you want to use a timing pointer and external crank trigger in which it has provisions for, as well as being 2 piece.......
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
