General Maintenance & Repairs - Window Adjustment
View Full Version : Window Adjustment
MIDNITE Z
06-09-2012, 10:16 PM
After the regulator and window motor are installed. How do you adjust the height of the window?
wssix99
06-10-2012, 12:06 PM
If you are asking this question, you either:
- Have this problem: http://ls1tech.com/forums/general-maintenance-repairs/961435-window-doesntt-go-up-all-way-pics-included.html
- Or something is broken
- Or you adjusted the plastic stops at the top of the door while you took out the regulator. (There are two of them.)
Typically after changing a regulator, the window glass should be right were it was before you started the job.
MIDNITE Z
06-10-2012, 10:02 PM
I fix it.....I adjusted the screws on the track
