Carbureted LSX forum - wiring my f body alternator carb ls1
toughy v8
06-10-2012, 08:10 AM
can you chaps help me i need to wire my f body alt (the car is not an fbody) but i dont know which wires i need to hook up to im hearing 5v here and resistors there and its getting a bit confusing.
thanks in advance
wildcamaro
06-10-2012, 08:58 AM
Should be able to use one wire (brown) for charging, I'd buy the correct pigtail or modify one if you have it already
Pop N Wood
06-10-2012, 09:30 AM
This link has pretty simple instructions.
http://www.ls1tech.com/forums/conversions-hybrids/779728-thee-alternator-faq-thread.html
Beside the main power out you just need to hook up a single voltage sensing wire preferably through the dash charge light. If you don't have a light available, then use a resistor like shown in the diagram.
kyles06crew
06-10-2012, 03:19 PM
I would use the lamp as the resistor so when it charges it will go off.And you know it is charging and if you throw a belt it will come back on.
GC99TA
06-11-2012, 07:25 PM
This is how I did mine as well (with the resistor). No issues.
ZONES89RS
06-12-2012, 01:31 PM
I would use a 87-92 F body alternator in the bracket you have, it will work, with a bit of thinking and lines up perfect. But thats me.
CBRAKLR85
06-12-2012, 09:07 PM
Any pictures of this set up?
Thanks
TJ
ZONES89RS
06-13-2012, 07:01 AM
I put them on my truck brackets and did test fit a f body bracket with success, but only have pics of the truck setups.
streetknight2
07-07-2012, 09:29 PM
Had a similar ?
I don't have an alternator at all. Was thinking of ordering one of the one wire deals off Ebay. This is a carb fox body. Car doesn't have a light, but does have an autometer volt gauge. Do I still need to use a resistor?
dirty39212
07-07-2012, 10:39 PM
Hey zones throw up a pic of the truck bracket set up
ZONES89RS
07-08-2012, 10:45 AM
http://i157.photobucket.com/albums/t74/ZONES89RS/c6d83a03.jpg
http://i157.photobucket.com/albums/t74/ZONES89RS/156a0f73.jpg
http://i157.photobucket.com/albums/t74/ZONES89RS/d24cc3d4.jpg
That is the 85 TA, 86 TA then my 94 gmc.
lselco
07-24-2012, 12:04 AM
zone what all did you have to do to make it line up? looking to go that route.
ZONES89RS
07-24-2012, 10:29 AM
Nothing, it just lines up, one side needs the dowel removed,, then a washer or two between the bracket and alternator so there is no stress when the bolt is tightened. Used a newer alternator on the 85 TA, had to grind the bracket a bit, but the 88-92 v8 and 88-95 v8 half ton alternator are best.
streetknight2
07-24-2012, 12:21 PM
Thanks for the help guys. I got my F body Alternator on my car. Got it out of the bone yard and they left the pigtail on it for me. I ran the wire on the pig tail to a light I bought at the parts store and put in the dash, then over to 12v with switch on and it works great.
Just like link above.
http://i172.photobucket.com/albums/w25/streetknight2/wiring.gif
lselco
07-24-2012, 11:39 PM
thanks fo the help zone
ZONES89RS
07-25-2012, 06:38 AM
Np, as long as it is a truck or you have a cowl, it is a stupid cheap alternative to a f body or custom setup with a carb.
Jeff Smith
07-25-2012, 09:45 PM
Good information..I need add 470resistor on ..
wildcamaro
07-27-2012, 10:39 AM
Can I run the wire through my stock voltmeter on my 81 camaro? Wouldn't it do the same thing as the charging light?
Pop N Wood
07-27-2012, 04:38 PM
No .
