onehardmaro
06-10-2012, 10:32 AM
Anyone have gas in tank leak or get siphoned out just by removing fuel filter? I assumed only gas in the line would drain out? The entire tank drained out when i removed the filter. I'm guessing all the pump components dissolved or corrosive damage.
Some history. Car sat idle for almost six years with about 5 gallons of fuel. I added a fuel additive and filled with new fuel without draining tank. Replaced battery and car started right up. Funny smokes and smell for 10-15 minutes; eveything cleared up after that.
Car even drove fine for approximately five miles. Now no fuel at the rail. This is when i removed fuel filter to replace and all gas drained from tank. New filter is on and a gallon of fuel was added to tank. I can hear the pump, but still no gas at rail.
Bad pump? Replace pump only or entire assembly(expensive)?
Thanks,
Thanks,
