General Maintenance & Repairs - What is this?
View Full Version : What is this?
Sladester2
06-10-2012, 01:23 PM
Noise coming from rear end when the back hits a bump or something. I can push it sideways a little. I was thinking maybe its something to do with the sway bar?
http://www.youtube.com/watch?v=gd2H_AJ5TeA&feature=plcp
mezzyshreder
06-10-2012, 01:28 PM
Sounds like a loose bracket of some sort. Possibly in the suspension. Put it on a lift and shake it. Have someone look for where the noise is coming from.
Undertow74
06-10-2012, 01:35 PM
or your shock tower nuts are loose. regardless, something is loos and get that on a lift. or you say you can push it sideways, is your panhard rod jacked up or loose? are your rear wheels centered?
Sladester2
06-10-2012, 01:48 PM
It just rocks semi-easy I will for sure get it on a lift thougj
Sladester2
06-10-2012, 04:07 PM
I have had to replace my sway bar before because my last one snapped. And I just got need wheels and tires sooo could be those
Sladester2
06-10-2012, 08:18 PM
It was a bolt from the sway bar. I had to replace it before guess I didn't tighten enough
