30th t/a
06-10-2012, 01:47 PM
Not thinking of lubrication, I wiped the all of rocker's and brand new 7.425" Comp pushrods down with a nice clean DRY towel. Then I installed them and started up my 77k mile LQ9. Within a few seconds there is a chirping noise coming from the valvetrain.
So after the light came on in my head that the rockers & pushrods needed lubricated before installation, I removed the rockers & pushrods, soacked them in fresh oil and wiped a thin film of gease on top of the valve stems and in the rocker arm "divet" where the pushrod seats.
Fired the engine up and it sounded perfect. I thought everything was fixed. It ran for a about 30 minutes like that and now all of a sudden the chirping noise is back.
Notes: I did do my first cam install on this engine, Used LS6 cam, brand new LS6 valve springs & Comp Pushrods, and I did replace the O-ring on the oil pickup.
what could be wrong?
Did I ruin the valve steams from having the dry rocker's on them?
O ring not installed properly?
I seriously doubt I bought a engine with bad lifters (I know its still possible though)
thanks for any help.
