Crank position sensor relearn?
Old 03-30-2004, 10:09 PM
whitt1's Avatar
Default Crank position sensor relearn?
How do you do a crank position relearn sequence?Does anyone know?
Old 03-30-2004, 11:21 PM
Restricted User
EFILive's Avatar
You need a scan tool to initiate the CASE (Crank Angle Sensor Error) learn procedure.
There must be no DTCs set.
The the engine should be at operating temperature.
The tansmission in park/neutral
The handbrake firmly applied.
Keep you foot on the brake as a safety precaution.
Once the scan tool has instructed the PCM to start learning do the following:
Press the accelerator pedal until the rpms rise over 4500rpm, the PCM will cut fuel to the injectors for about 1/2 second.
When you detect the "stumble" release the accelerator pedal immediately.
Wait for the engine to reach idle speed again.
Turn off igintion for 10-15 seconds to allow the PCM to "save" the learned information.
That's it.
I only know of two scan tools that can initiate the CASE learn procedure: Tech2 and EFILive. There may be others, you would need to check which ones do and which ones don't.
Regards
Paul
Old 03-30-2004, 11:27 PM
whitt1's Avatar
Thanks,I have EFILive I'll try it tommorrow.
Old 03-31-2004, 01:05 AM
Restricted User
EFILive's Avatar
The full EFILive instructions can be seen if you click the "More info" button in the CKP relearn window.
Paul
Old 03-31-2004, 01:26 AM
66ImpalaLT1's Avatar
If you have V6 make sure you have 6.2.0 or newer.
I got bit by this last week when I was scratching my head trying to figure out why nothing happened when I reved it up.
Quick Reply: Crank position sensor relearn?
