tylert14
06-11-2012, 05:06 AM
Hey guys, I apologize if this is not the appropriate forum for this question, but it seems to me that I would get an audience with the most input here.
I have a stock 5.3L LS engine going in a 73 240z. I am using oem C6 oil filled engine mounts and an energy suspension polyurethane transmission mount.
What I am looking for is some input on how much side to side movement I should expect out of this mount combination. If any C5/C6 guys would like to add any input I would greatly appreciate it!
I am expecting mostly educated guesses, but if someone has measured movement with the drivetrain loaded, well that would be even better. :burn:
FYI, I am inquiring because with this Z the space is very limited. I am facing some pretty close clearances between the transmission and transmission tunnel on the passenger side. Exhaust system clearance is going to be very tight as well.
I'm just trying to see what I should set as a "minimum clearance" value in my head so that hopefully I don't have any clunk clunk issues to resolve after my first test drive!
Car in question. (Please don't mind the dirty radiator :p)
http://i1102.photobucket.com/albums/g456/tylertitus14/1973%20Datsun%20240Z%20Build/IMG_1911.jpg
Thanks for your time.
-Tyler
-Tyler
