Cadillac CTS-V - Whats the Normal Operating Temperature? 180% or 195%?
87vertgt
06-11-2012, 09:58 AM
tanks boyz
kl2onik
06-11-2012, 10:28 AM
I see temps even reaching 210 at times when I'm at idle on a hot day. Usually Im in at 198 or so. This varies between every v man depending on what they have done to the car, your pump, thermostat, stock or aftermarket radiator etc.
tommycompton
06-11-2012, 10:33 AM
He's driving a Vee 6. Maybe LS tech isn't the right forum to get answers.
NeverSatisfied02
06-11-2012, 12:38 PM
Yeah... Completely different. Go to cadillacforums and ask the v6 guys
lollygagger8
06-12-2012, 12:01 PM
Just for shiggles...what are you guys running at??
BudRacing
06-12-2012, 12:33 PM
185 normally. I think the PO put in a lower thermostat.
NeverSatisfied02
06-12-2012, 12:36 PM
Mine sits top dead center on the gauge whatever that is... Lol haven't put the 160* in yet.
Gabbiani
06-12-2012, 12:38 PM
Stock stat - fans lowered a little. 195 most days. Oil will creep around 210 on a hot day.
NeverSatisfied02
06-12-2012, 12:41 PM
Suppose mine is prob the same as yours. Pretty sure my buddy had them turn the fans on at a lower temp when he had it tuned but the stat is still stock on mine as well.
Stone17
06-12-2012, 12:50 PM
160f thermostat and lower fan.
In the morning my car runs about 177f on the 26 miles to work (no traffic).
After work in traffic and hot weather car runs about 210f in traffic and 196f in open air.
SSmokd U
06-12-2012, 01:20 PM
Mine always sit at 192 when it's moving. If I am sitting still or in traffic it bumps up to around 210-215. I have seen it as high as 230 before but the gauge is just barely above the halfway mark.
Skidmarcx
06-12-2012, 01:30 PM
Yea I've seen mine hit 230 once in traffic and 117 outside... Not a good combo. I tossed in a 180 stat and the fans turned down to 195... Works well when the weather is fair, but summer time it doesn't matter its gonna be hot since the radiator is the same
87vertgt
06-12-2012, 03:31 PM
Thanks for the responses boyz.
working on a conversion.
Dmax/04V
06-12-2012, 03:33 PM
Even with a RD radiator i run about 195 cruising, no higher than 202 in traffic though. Stock therm, fans come on earlier though.
ColeGraham
06-12-2012, 07:34 PM
160* Thremostat and lower fan...I am normally running in the 174-177 range, and on really hot afternoons i will creep into the mid 180s. I rarely see 200+, the last time I did was yesterday. 107* Ambient Temp, outside temp on the DIC said 123, and i was sitting in a line to get off base. Full A/C going, and the highest my water temp got was 201.
lollygagger8
06-13-2012, 12:22 PM
Just to be crystal......
Are we talking about the dial guage on the bottom left of the instrument panel, or one of the digital ones you can toggle through?
Hmm this has got me a little worried. My wife's car while sitting in the drive will hit up tot 230* and then drop down the 200s then rise up again and then drop down. This happens over a couple minute cycle. Cruising it sits at 180ish-195. Think maybe the thermostat is sticking?
