Gears & Axles - Which carrier shim kit?!
View Full Version : Which carrier shim kit?!
nimrod.sixty9
06-11-2012, 05:10 PM
Which carrier shim kit can I get? I have searched and I cannot get any clear answer.. 7.5... 7.625
This is the one that came up when I searched via vehicle
http://www.jegs.com/i/Motive+Gear/683/1105/10002/-1
This one as similar item
http://www.jegs.com/i/Richmond%20Gear/836/38-0006-1/10002/-1?CT=999
This one searching vehicle, lists that it works for both
http://www.summitracing.com/parts/RAT-1105/Application/?prefilter=0
Or if there are any others? Sponsors?
TIA
FirstYrLS1Z
06-11-2012, 06:13 PM
7.5 is the same as 7.625.
a 7.625 rearend has a 7.625 OD ring gear mounted on a 7.5 carrier.
a 7.5 rearend has a 7.5 OD ring gear mounted on a 7.5 carrier.
rearend parts are the same: bearings,seals,shims,etc.
nimrod.sixty9
06-11-2012, 06:23 PM
So I can put any of the kits listed for a 4.10 Richmond swap?
nimrod.sixty9
06-11-2012, 07:44 PM
Got this:
http://www.summitracing.com/parts/RMG-3800061/
Tell me I did good...
FirstYrLS1Z
06-11-2012, 09:04 PM
all the shim kits are basically the same.
the difficult part is using them to set backlash while having enough preload on the carrier bearings.
nimrod.sixty9
06-11-2012, 11:05 PM
Thank you sir. Hopefully this kit will get me set right.
Also, does anyone know the break in procedure for Richmond gears?
I found this:
Street vehicles should be driven at normal street driving speed for approximately 10 miles, then stop and let cool for 30 minutes. Do this 2 to 3 times.
Does this sound right? Anyone with experience?
