Black96z28
06-11-2012, 05:33 PM
You will need some small screwdrivers or picks. You will need to know how to solder. You may need some patience.
The replacement bulb is Edit: 8640 which is a 'T-1 1/4' form factor bulb. These were not easy to find a part number on. There are many people who charge between 10-25 dollars for 3-8 of these bulbs. Ripoff.
http://www.the3rdhonk.com/lsx/flswitch/DSC_0428.JPG
Start off at either end, you will pry the casing apart while lifting the outside over the tabs on the side. (next 2 pics)
http://www.the3rdhonk.com/lsx/flswitch/DSC_0437.JPG
http://www.the3rdhonk.com/lsx/flswitch/DSC_0429.JPG
I recommend that you wedge the cases apart after you pry the first half. This will keep it from going back together.
http://www.the3rdhonk.com/lsx/flswitch/DSC_0438.JPG
Once you clear all the tabs, the switch will pull apart easily. Be careful as the parts and tools like to go everywhere.
http://www.the3rdhonk.com/lsx/flswitch/DSC_0439.JPG
This is the inside of the Fog Light switch. Both switches are identical inside, except for their contact bridge.
You have 4 terminals to solder your new lights to.
http://www.the3rdhonk.com/lsx/flswitch/DSC_0430.JPG
http://www.the3rdhonk.com/lsx/flswitch/DSC_0431.JPG
http://www.the3rdhonk.com/lsx/flswitch/DSC_0433.JPG
Both lights have a sleeve on them and you will want to use them on the new bulbs. In order not to tear them, soak the whole bulb in hot water for a few minutes before trying to remove.
http://www.the3rdhonk.com/lsx/flswitch/DSC_0434.JPG
http://www.the3rdhonk.com/lsx/flswitch/DSC_0435.JPG
This is the inside of the ASR switch below.
http://www.the3rdhonk.com/lsx/flswitch/DSC_0442.JPG
:thumb:
:thumb:
