24x Conversion
not wanting to hop in on your thread but i've looked around "search" could find any info on keeping the MAF with that swap...I'm getting all the items needed to do the swap n just needed to know if it was kept
There is very minimal rewiring to be done. Everything is just repinning other then your power and ground wires for your coilpacks. You need to tie the pink coil wires into the thickest gauge off one of the c1xx connectors that connects up to the stock coil location. You just need to trace the wire down to get to the thick gauge wire. The ground coil wires i just grounded off to the drivers side head with the rest of the other grounds. If your looking to clean it up then you can re wire them to run down to the back of the block. Thats really about it. Just make sure to check out lethalbirds and my build threads as there a couple wires that are not mentioned in the swap if they are kept or not as they are all outlined in those threads if they can stay or be deleted and where they go.
