Fueling & Injection - fuel Injector Help
jeff keyuk
06-11-2012, 06:07 PM
Hi Guys! This is what I have, Purchased Venom 36Lbs Injectors, I have EFI Live tuning tool, Ive just finish Cam Heads, Fast intake change.Looking to load tune for the fuel Injectors,Back when purchase Tuning video for Greg B.He as gave me excel spreedsheet on changing injectors , But his specs,are not on 36lbs injector his specs are on bocsh 30 or 39lbs injectors. There are 4 tables is to change, The first table Injector flow Rate is no problem, Its 2nd table Injector offset B3701 that I am looking to change.Just wounding if anyone can helpout.Thanks jeff!
ZL1Killa
06-12-2012, 03:55 AM
send me a pm with specifics or we can pm and call each other/email to sort this out. Only issue with call right now is I'm on night shift. Will be off by Thursday
jeff keyuk
06-12-2012, 08:22 PM
Hi Z ! Just tryed to PM You! It would not go through. SENT ME YOUR E-MAIL Address.
As far as speces I have are Venom HP-636 Injectors 36Lbs. Advertised Flow Rate 36lbs. Inj. Advertised (cc/min)390.cc/min Injector Impedance 15.9ohms Inj. Style:Bosch/amp.
I can e-mail you my Inj. Flow Rate numbers,B4001 Can you help me with the Inj. offsetvs voltsTableB3701.Thanks again jeff
ZL1Killa
06-14-2012, 12:14 AM
strange... my box is not full..only have 20 or so messages
jeff keyuk
06-18-2012, 09:03 PM
Hi Z ! just like to let you know, Work out all my tables.
ZL1Killa
06-19-2012, 07:04 PM
your last post didn't read right.. but I take it you get everything worked out.
jeff keyuk
06-20-2012, 06:25 AM
yes ! thanks jeff
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
