Stereo & Electronics - Battery relocation question
notnilc20
06-12-2012, 02:32 AM
I'm wanting to do this but I have a question. I've researched this a bit but I'm wondering if it's possible to just take the factory Pos and Neg wires and connect them to the new wire and run it back to the rear of the car and just connect them to the pos and neg terminals on the battery?
If not......why not? I pretty sure it's a too long a distance but I just wanted an answer from the experts. Thanks
99Bluz28
06-12-2012, 11:42 AM
I'd get a power distribution block to mount up front and run 1/0 awg power/grd cables (to minimize power lose on the long run to the back). I'd also go with a 1/0 awg cable from the alt., and starter to distribution block. You might also consider upgrading the negative/grd cables up front to.
notnilc20
06-16-2012, 05:47 PM
OK, thanks.....also I hear people recommend a 100amp fuse to be put in the pos cable near the battery. However, what is a good 100 amp fuse to use on a 1/0 gauge wire? I can't find anything. Thanks.
99Bluz28
06-16-2012, 07:25 PM
I'd get a Stinger#SPD5204 (1/0 ga. in/out, uses ANL fuses) you can get them for about $30 each. I'd put one by the battery, and one under the hood and get some 200amp fuses. Another option is circuit breakers, get two Stinger #SGP90200(200 amp) then theres no fuses needed.
notnilc20
06-17-2012, 11:00 PM
Alright....sounds great....thanks for you help so far. Just to let you know, I'm not running any big stereo and amplifiers for sound.....only thing I'll be connecting to the battery other than factory stuff is a compressor for my air ride suspension. Do you still recommend the 200amp circuit breakers? I think I will go with the circuit breakers over the fuses.
99Bluz28
06-17-2012, 11:48 PM
The 200amp fuses/breakers are to protect the power cable, you can go smaller if you know the starter won't pop the breaker on start up. I'm not sure exactly what the amp draw is from the starter, bu I'd still go with at least 150amp breakers.
notnilc20
06-18-2012, 06:11 PM
excellent info....thanks again.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
