jaycenk
06-12-2012, 12:24 PM
Truck SOLD!!!
It is set up to tow. It has Limited slip rear, helwig aftermarket add on rear sway bar, helper springs and shocks installed to keep the vehicle level when towing. This Tahoe came from the factory with HD radiator with integrated trans cooler, and separate oil cooler. A/C compressor was replaced with an updated GM unit almost 2 years ago. Blows cold A/C . Also has rear A/C controls and vents and also blows cold. This Tahoe has the "Barn Doors" (as GM called it) at the back with defroster strips.
Has grey leather interior with grey carpet and grey plastic panels. The leather has some wear but only one tear in the front passengers seat. Gauge cluster includes Speedo, Tach, Oil Pressure, Volts, Water Temp, and Fuel level. There is an after market stereo system installed. 4 newer Polk door speakers, DVD head unit with the ability to add a backup camera (never got around to installing one) 2 amps, one for main speakers and one for the sub. There is a small single 12 in a box in the rear of the truck. The dash was cracked when I bought it several years ago so I bought a dash cover for it.
This truck has run great for me over the past couple of years I have owned it. Most of the front end was rebuilt. Newer Monro reflex front shocks, Idler Arm, inner and outer tie rods all replaced as well as the drag link, and pit-man arm, (couldn't get the old pit-man arm off the drag link) with Moog parts. Intermediate shaft was also replaced with a new GM part. No cheap stuff. On a scanner there were zero codes and zero misfires the last time it was at my mechanics . It does not leak any oil. Does not smoke when started or when you get on it. The alternator was rebuilt locally and upgraded from the original 105 amp to 160 amp with all new bearings, windings, regulator, and brushes. It is the factory case with the same size pulley so the stock belt size remains the same. Battery has been replaced in the past 6 months, as well as new bigger cable from the alternator back to the battery. Has cruise control but has never worked for me. Has intermittent wipers and they work (most stop working). I replaced the delay pack on the wiper motor earlier this year. Over all it has some wear but it has been great to me.
The truck is located in Florida west of the Tampa area. If you are local and want to see it PM me. I have tons of pictures and I also have a pic of the RPO Codes.
[/COLOR]http://i303.photobucket.com/albums/nn131/jaycenk/98%20Tahoe/100_4422.jpg
http://i303.photobucket.com/albums/nn131/jaycenk/98%20Tahoe/100_4421.jpg
http://i303.photobucket.com/albums/nn131/jaycenk/98%20Tahoe/100_4419.jpg
http://i303.photobucket.com/albums/nn131/jaycenk/98%20Tahoe/100_4433.jpg
http://i303.photobucket.com/albums/nn131/jaycenk/98%20Tahoe/100_4393.jpg
http://i303.photobucket.com/albums/nn131/jaycenk/98%20Tahoe/100_4394.jpg
http://i303.photobucket.com/albums/nn131/jaycenk/98%20Tahoe/100_4397.jpg
http://i303.photobucket.com/albums/nn131/jaycenk/98%20Tahoe/100_4396.jpg
http://i303.photobucket.com/albums/nn131/jaycenk/98%20Tahoe/100_4400.jpg
http://i303.photobucket.com/albums/nn131/jaycenk/98%20Tahoe/100_4399.jpg
http://i303.photobucket.com/albums/nn131/jaycenk/98%20Tahoe/IMG_0462.jpg
