Paint & Body Work - Going to pull the trigger on the CETA mod tomorrow, Advice please!
02WS6_Publix
06-12-2012, 06:14 PM
So I'm off work tomorrow and I have planned to finally pull the trigger on the CETA mod for my WS6. I am planning on using Plasti-Dip so that I can remove it at anytime if need be.
So with all that being said the point of this thread is to ask for advice from anyone who has done this and have a few pointers before I start. I assume I will just need Semi-Gloss black, newspapers, and tape.... then a lot of time. haha
k_garretson23
06-12-2012, 06:27 PM
I sanded mine with some really fine grit, then primed painted, did not clear it for the flat look. Since youre using plasti dip just make sure the surface is clean, wax and grease free, mask it of and paint it. If you dont like it peel it off. Best of luck
karpetcm
06-12-2012, 06:59 PM
Most of it will be prep, as long as its clean and taped off painting it should be easy.
02WS6_Publix
06-12-2012, 07:10 PM
Sounds easy enough, I hope it turns out to be that smooth tomorrow. lol
I'll be sure yo update with some pictures for everyone.
karpetcm
06-12-2012, 07:28 PM
I might do it with my vette, not sure yet. Goodluck tomorow, for sure post the pics.
ramairetransam
06-12-2012, 08:00 PM
i waxed my mini ceta mod area , it will come off easier , im not sanding my car and then having sand marks under it .
02WS6_Publix
06-12-2012, 08:50 PM
Very good point about the sand marks.... If i just wipe the prep area down with Rubbing Alochol do you think that will be a good medium between sanding and waxing? or should I postpone and wax before i paint the CETA mod?
02WS6_Publix
06-13-2012, 07:02 PM
In the middle of coat #1 and waiting before I apply coat#2.... The Plasti-Dip looks almost flat black, Should I clear coat on top of it? I'm worried if i do that then i wont be able to remove it if need be.... Witch was the point of using plasti dip. Anyone know if I can or not?
ramairetransam
06-13-2012, 07:13 PM
do 4 coats or 3 and then if you wanna do something paint over the plastidip , i think it will looks good satin/flat . But you can paint over it . Also when i do my 4th coat just after i sprayed it i pulled the tape . I had a friend that waited and it pulled some dip .
02WS6_Publix
06-13-2012, 07:16 PM
Oh shoot, thanks for the tip about pulling the tape, thats good to know for sure!
I will be adding coat #3 here soon and then see what its looking like. =D
ramairetransam
06-13-2012, 07:27 PM
yeah 3-4 depending on how heavy you did it Take some pics.
02WS6_Publix
06-13-2012, 09:03 PM
I stoped at 3 coats... The tape was stuck to the Plasti a slight bit so i just gently ran a razor along the line to seprate the two and It worked like magic! There is one spot in the left corner where the plasti got me :( but other than that it looks awesome I'm working on getting my pics uploaded for everyone.
TRTC360
06-13-2012, 09:15 PM
i'm a n00b to this forum, what exactly is the CETA mod?
02WS6_Publix
06-13-2012, 09:26 PM
CETA= Collectors Edition Trans Am. Also known as the Yellow TA's with all the black accent! haha :) Ill post a pic in like 4 min and show you how it looks.
02WS6_Publix
06-13-2012, 09:39 PM
This is the after picture
ramairetransam
06-13-2012, 09:51 PM
Looks great
firemech21
06-13-2012, 09:52 PM
Looks good man, car looks great too man.
02WS6_Publix
06-13-2012, 09:57 PM
Thanks, I really am happy on how it turned out. I am a little surprised at how much it accents the rear end. I guess its because ive never seen the CETA on any TA here in town (or in person) but dang I looks good on our cars! haha
Touche' RAMAIRETRANSAM, on the flat black comment. I like it flat.
MrMixnMatch
06-14-2012, 07:59 AM
Good job! Think that'd look great with some tinted tails! I might have to give that a shot this weekend now lol
jonisalex
06-14-2012, 08:32 AM
Great job 02WS6_Publix! Definitely can tell you spent a lot of time in it. :cheers:
02WS6_Publix
06-14-2012, 10:08 PM
Ya know its ironic that you would say that, I figured going into it all that this would take me 1 1/2 hours-2 hours max....... Well I couldn't have been anymore wrong. lol It took a total of 4 hours from the begining of prep, all the way until I was cleaned up. :huh:
Not sure if im just REALLY slow, or if I was trying to make it perfect but at the end of the day I love the new look! =D
masnart2000
06-15-2012, 11:48 AM
Yeah I just lightly sanded after taping off the area, and then did 1 coat black primer, 3 coats of flat black and called it a day. It still looks fine 3 years later. :)
