05 5.3 with a 04 comp and harness?
Old 06-12-2012, 06:42 PM
lt1chevelle's Avatar
Default 05 5.3 with a 04 comp and harness?
will a 04 harness and comp work on a 05?
Old 06-12-2012, 09:31 PM
LS1Tech Sponsor
psiconversion's Avatar
Generally speaking YES. What is the application?
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old 06-12-2012, 09:34 PM
its going in a 63 nova, i have a 5.3 out of a 05 tahoe and the harness and comps out of a 04 suburban
Old 06-12-2012, 09:36 PM
LS1Tech Sponsor
No, that shouldnt be a problem at all.
Jon
PSI
__________________
Ebay Store
Old 06-12-2012, 09:37 PM
ok, thanks!
Old 06-12-2012, 09:41 PM
what if one is drive by wire and the other is cable?
Old 06-12-2012, 10:22 PM
Bo185's Avatar
Just swap to a DBC or DBW throttle body as needed. Which ever fits your harness. You will need to make sure the intake has the nutserts for the throttle cable bracket. If not just fab one or pick up a earlier intake for cheap.
Old 06-12-2012, 10:25 PM
ok i already have a DBC ls1 intake and the harness is a DBW so could i just remove that from the harness?
Old 06-12-2012, 11:50 PM
Bo185's Avatar
Yes and no. Your PCM has to support the DBC some of the late truck PCM will not support it. So you need a PCM that will. Whats the ser. number of the PCM you have?
Also you would need to add the IAC and TPS wires to the DBW harness.
Why not just save the trouble and run the DBW???
Old 06-13-2012, 12:17 AM
ill have to check the serial numbers on it, the only reason i ask is because the ls intake i have is drive by cable.
Old 06-13-2012, 12:51 AM
Bo185's Avatar
So the truck DBW throttle body will bolt right up to the LS1 intake why not use it.
Old 06-13-2012, 01:06 AM
Guess I could just do that. Was wanting to run the LS throttle body so I could run a bigger aftermarket one. I would have to swap out the throttle pedal as well to a new DBW style. 207656 are the number the guy sent me on the comp.
Old 06-13-2012, 11:15 AM
LS1Tech Sponsor
Agree with BO105. If you have a DBW harness I would stick with that setup. You can repin the harness for DBC, but as stated, you will have to make sure you have a PCM that can support the IAC. Also, remember that the truck intake is going to have different injector connectors than the car one, so that would be another harness change you will have to make.
JON
PSI
__________________
Ebay Store
Old 06-13-2012, 01:00 PM
i guess ill wait to see if the comp can handle the dbc an if not ill just keep it as DBW, when i do that ill have to replace the throttle pedal to work with the DBW (motor is going in a 63 nova)
Jon- would be the cost be on switching out the injector connections?
thanks for all the help guys!
Old 06-13-2012, 11:58 PM
Bo185's Avatar
PCM's 2003 to 2007
SERV. NO.- HWD NO.
12576106 - 12570558 (IAC DRIVERS INSTALLED)
12582605 - 12580786 - 2003
12586242 - 12583660 - 2004
12586243 - 12583659 - 2004 (IAC DRIVERS INSTALLED)
12589463 - 12589162 - 2005
12589462 - 12589161 - 2005 (IAC DRIVERS INSTALLED)
12589463 - 12589162 - 2006
12602802 - 12589162 - 2006
12602801 - 12589161 - 2006 (IAC DRIVERS INSTALLED)
12602801 - 12589161 - 2007 (IAC DRIVERS INSTALLED)
Which ever numbers listed above that have the IAC drives above will work with DBC.
One other thing if you worried about TB size just look for a 90mm truck intake off a TBSS or Gen IV 4.8/5.3L intake they will have a 87mm TB to start with and flow as well as the old LS6 car intakes. You can also use the truck DBW throttle body that comes on them you just need a aftermarket plug converter box for the later TB to earlier one. Also those injectors are 30# units most apps and will plug right up to the old truck injector harness. Just be aware that around 2009 GM changed MAP sensor so you have to mod those intakes to fit hte earlier MAP not a show stopper though.
Old 06-14-2012, 06:47 AM
LS1Tech Sponsor
LT1, give us a call for the injector pigtails.
Jon
PSI
732-691-6531
__________________
Ebay Store
Quick Reply: 05 5.3 with a 04 comp and harness?
