water pump
Old 06-12-2012, 06:42 PM
oldtimelt1's Avatar
Default water pump
Anybody cut some of the water pump shaft off to gain fan clearance? If so how much.
Old 06-12-2012, 07:00 PM
99VetteFRC's Avatar
I think everyone is pretty much running electric fans.
Old 06-12-2012, 08:12 PM
S10xGN's Avatar
I cut some off the shaft on my Buick GN motor, it was hardened and I had to use a cut-off wheel. You'll prolly find the same thing with any pump...
Old 06-12-2012, 08:59 PM
oldtimelt1's Avatar
What i have is a 73 vega with a 04 gto engine and i already cut the radiator support and moved the radiator about 2 inchs forward. I have 3 different electric fans and non will fit, maybe another inch and i might have enough room. I don't want to put it in front because i'm puting A/C in.
Quick Reply: water pump
