General Maintenance & Repairs - No Hazard/Turn Signals/Brake Lights
Shinn98ls1
06-12-2012, 07:58 PM
As the title states, what would go bad that would cause the loss of all 3?
BLKWS6
06-12-2012, 10:04 PM
dumb question, but have you checked all your fuses on the side of the dash? sometimes i know if you have a bulb out it will not let the flashers flash...it will be solid on your dash....but that shouldnt affect all 3 at the same time.
but start with the fuses...then check your bulbs.
Shinn98ls1
06-13-2012, 07:37 AM
but start with the fuses...then check your bulbs.The turn signal is not solid in the cluster. When i try to turn the signal on left or right, it does nothing.
BLKWS6
06-13-2012, 08:10 PM
Well i would just start with those places. Mine does the same thing if a bulb is out. sometimes it will light up. sometimes it wont. just depends on the cycle it seems sometimes or what bulb is actually out. it shouldnt be that way...but things happen.
blue98Z
06-19-2012, 02:37 AM
I'm having the same problem right now myself. The other night it did it and I started checking fuses and all were good. So I tapped on the light switch and they came on :confused: so after about a week, it happened again. Tapping doesn't work now and all fuses are still good. Bought a new switch and that didn't fix it. Wondering if it's the little dial next to it now?
I'll be sure to update if I find the cause. Please do the same cause I need this thing on the road again soon.
DisasterFormula
06-19-2012, 09:46 AM
Check your grounds?
blue98Z
06-27-2012, 01:32 AM
Not sure if you found your problem but, mine was in what looked like a junction block under the dash.
Pull the bottom piece under the steering column and you can see it bewtween the fuse block and steering column. I think I loosened mine up while running some wires or installing my Tick Master. Either way it didn't flicker or give me any more problems for a 20 mile trip.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
