Carbureted LSX forum - any gain switching to carb
Rpayne41985
06-12-2012, 08:21 PM
You guys think i could pick up switching to carb set up, mods are in sig
bwkmaro
06-12-2012, 08:50 PM
youll only pick up if you can get a better flowing intake and or you have flat spots in your tune. power for power fuel injection and carb are the same
bfurches
06-12-2012, 08:59 PM
Not here to argue, just putting in my .02
Yes...you will pick up and make more peak hp with a carbureted setup (assuming you are talking traditional open plenum, like a vic jr or gmpp).
Pop N Wood
06-13-2012, 05:38 AM
I use to have links but there have been several write ups in car mags where they did pick up a fair amount of top end HP from switching to a carb and carb intake. If you look at the EFI and carb'd versions of GM crate motors they typically rate the carb'd version with 35 more HP than the EFI. The surprising thing is torque numbers aren't off by much either.
So yes, you might go faster
ZONES89RS
06-13-2012, 07:09 AM
In general, yes. And a front fed efi inlet will not distribute nitrous as well with a plate. The dense mix may be the reason, but I have yet to see a car go slower with a carb unless it was undersized parts.
daniel044
06-13-2012, 12:17 PM
The only plus about a carb vs efi is that efi is a bit more tuner friendly.
Figuring out a tune in a carb can take awhile and does take some experience. As long as you have a good timing box (MSD 6010/6012) and know how to work a wideband then I would go carb all day long. Changing jets is easy but getting to that exact sweet spot does take some time.
ZONES89RS
06-13-2012, 03:38 PM
If you have a knack for hands on it is easy. EFI tuning is another ball game with the software. For a drag application the carb isost likely the way to go for power with the ease of the setup, simplicity, ect. So damn cheap when it comes down to a budget or low buck setup.
speedtigger
06-13-2012, 07:52 PM
With a 4500 converter, I would definitely go single plane intake with carb or efi.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
