Chevrolet Camaro 1967-2002 - ls1 rebuild or ls3
caturnbull1
06-13-2012, 01:02 AM
ok so i am thinking about either rebuilding my ls1 but putting bigger heads and cam in it or should i just go with ls3?
TXSZ66AVLANCHE
06-13-2012, 06:05 AM
I built a ls1 earlier this year, total cost about $1700 (price of bad ls1 included in price) and it made 331 to the wheels. LS3 obviously give more potential for max hp. If you can afford the ls3, go for it.
BAMALS1
06-13-2012, 02:43 PM
I say LS3...
caturnbull1
06-13-2012, 04:40 PM
Yeah turn key ls3 is 8k thats the problem lol
TXSZ.....Where all did you get your parts and did you hone it and get it balanced or do it all yourself? all of that in the 1700?
lemons12
06-14-2012, 03:32 AM
Lq9 with an l92 top end.. Cam only you will be close to 500Rwhp with bolt ons.. Much much cheaper than an ls3 swap, Very similar results.
caturnbull1
06-14-2012, 04:49 AM
how easy is the swap?
TXSZ66AVLANCHE
06-14-2012, 06:05 AM
Built the engine myself, only thing the machine shop did was install cam bearing and surface the 243 heads.
00MaroonZ28
06-14-2012, 06:08 AM
You should probably start out with a budget and see which build will fit that budget.
TXSZ66AVLANCHE
06-14-2012, 06:17 AM
This week I ordered the first parts to build a LS3, going to be way cheaper that 8k
caturnbull1
06-14-2012, 06:18 AM
Id like to go cheapest looking for 400-450 rwhp. Did you have a lift for the car or just jacks to remove the motor?
Where at? That was just for turn key ls3
lemons12
06-14-2012, 12:02 PM
Swap your accessories/etc... The blocks are nearly identical so you are basically swapping in another ls1.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
