Changing to Aftermarket Head Unit
I tried to find a direct answer, but did not have any luck.
I want to get an alpine CDA-9833 and want to use the stock amp. I just get a wiring harness and wire it to the head unit and plug it into the stock harness, right?
Also, in the future, te head unit has a sub woofer pre-amp out, can I plug in a sub and amp to that and run the rest from the stock amp as wired above?
Thanks in Advance.
Thanks in Advance.
Copy & Paste Moderator
Do a search and you'll find plenty of information.
Here are a few links I found when I serached for "Aftermarket Headunit":
https://ls1tech.com/forums/showthrea...arket+headunit
--VIP1
--VIP1
