TriShield
06-13-2012, 11:15 AM
Gratuitous Excess vs. Unwarranted Exorbitance
http://media.il.edmunds-media.com/chevrolet/camaro/2013/ct/2013_chevrolet_camaro_group_ct_605125_717.jpg
Yellow flowers. Insanely fast cars. Nice.
By Josh Jacquot, Senior Editor | Published Jun 12, 2012
With muscle cars, it's all about horsepower.
So it's possible there's never been a greater case for dual-overhead-cam engine architecture than the 98-wheel-horsepower chasm between the 2012 Chevrolet Camaro ZL1 and 2013 Ford Shelby GT500. The Shelby, with a displacement some 350cc less than the Camaro, still manages to crank out enough horsepower to lay claim to having the most powerful production V8 ever built. Indeed, its massive potency alone makes a good case for choosing the GT500 over the pushrod-motivated Camaro.
But it gets worse for the Chevy.
The όber Mustang is also 227 pounds lighter than the Camaro. Combine that with its massive power advantage and it looks like curtains for the Camaro.
It probably would be if the ZL1 didn't have a couple trump cards of its own. And by that we're referring to its independent rear suspension and magnetorheological dampers. They're interesting high-tech features, but it's hard to imagine they would be enough to overcome a serious horsepower-to-weight deficiency, right?
The Basics
http://media.il.edmunds-media.com/chevrolet/camaro/2013/ct/2013_chevrolet_camaro_group_ct_605126_717.jpg
There's a lot of Americana in the photo.
In case you've been sleeping under a big block for the last 45 years, here are the facts: Camaro and Mustang comparison tests are to enthusiasts what ice is to hockey, what minivans are to soccer moms and what cheese is to tacos. This is the foundational bedrock of our passion for performance, and when two muscle cars as epic as these arrive at the same time the awesomeness is arresting.
And so are the numbers.
Power figures like this, not long ago, were the realm of hydroelectric plants. Rivers, not cars, produce this kind of mechanical energy. And as different as their output might be, some similarities exist under their hoods. They're both powered by port fuel-injected, Eaton supercharged, aluminum-block V8s. Ford rates the GT500's output at 662 horsepower and 631 pound-feet of torque. Chevy says the ZL1 pumps out 580 hp and 556 lb-ft. Although you'd never know it from behind the wheel, both utilize Tremec's TR6060 six-speed manual transmission.
And if we have to tell you the power goes to the rear wheels, you're reading the wrong comparison test.
Did That Just Happen?
http://media.il.edmunds-media.com/chevrolet/camaro/2013/ct/2013_chevrolet_camaro_group_ct_605128_717.jpg
What you can expect when you pit these two cars against each other.
Nothing is more humbling than watching a car with 100 fewer horses and the extra weight of an NFL running back disappear into the distance on a back road. But that's exactly what happened when we brought the two cars together to establish which is the best-driving muscle car ever. The answer, as improbable as it seemed, was as obvious as the Camaro's shrinking taillights.
Wait. Isn't this a Camaro? Yes, yes it is. The best Camaro ever.
The angriest Mustang in history, the car that had face-punched the ZL1 for months at auto shows and in Web forums was being systematically annihilated by that exact car. Every corner was another opportunity for the Camaro to drop trou and wave its giant bowtie-emblazoned butt in the GT500's face.
Driver swaps ensued to ensure impartiality, but a repeat performance sealed the deal. There wasn't anything to do but appreciate the stunning piece of work that is the 2012 Chevy Camaro ZL1. As one tester bluntly put it, "This might just be the best performance car General Motors has ever produced." A bold statement, for sure. But one for which there's much support.
How It Happened
http://media.il.edmunds-media.com/chevrolet/camaro/2013/ct/2013_chevrolet_camaro_group_ct_605124_717.jpg
This isn't the result you'll find if you drive these cars back to back on a twisty road.
Here's the amazing part about the ZL1's Shelby-stomping back road performance: It's not as if the GT500 makes no nod to handling. Plenty of effort was made to raise the Shelby's cornering ability to match the level of stupefying speed its engine can deliver.
Sure, it's saddled with a solid rear axle, but Ford has, in the last five years, refined the Mustang to the extent that, in GT form, we prefer it over the Camaro SS. And with the 2013 Ford Mustang Shelby GT500, the handling efforts are bigger than ever. Two-mode electrically adjustable Bilstein dampers coupled with unique spring and stabilizer bars are optionally available and fitted to our test car. Its Goodyear's Eagle F1 Supercar G:2 tires are as sticky as they are costly. Three-mode adjustable steering assist doesn't hurt, either.
Even so, there's a level of at-the-limit comfort in the 2012 Chevrolet Camaro ZL1 that you don't get in the GT500. On the road, the Camaro will rotate as commanded when its wheel is turned. In other words, there's less understeer in the ZL1 which, coupled with better steering feel, makes it more trustworthy. Perhaps most significant is that, in the real world, where bumps too often occur in less-than-ideal locations, the Camaro is more confident. The tables might turn marginally on a smooth road course, but the ZL1 will always be the more rewarding and easier car to drive.
Its Performance Traction Management (PTM) system, which doles out power at a level precisely metered to match available grip, makes the Shelby's "sport" stability control feel archaic in comparison. PTM eliminates the throttle-chopping punishment common to the Shelby and replaces it with rewarding acceleration at corner exit. And if you insist on measuring your manhood by switching both systems off completely, you'll live longer in the Camaro.
What the Instruments Say
http://media.il.edmunds-media.com/chevrolet/camaro/2013/ct/2013_chevrolet_camaro_group_ct_6051210_717.jpg
The ZL1 is still the car we'd choose to drive on a back road every day
If this were a contest of power plants alone, it should be obvious that the Shelby is the clear choice. Its modern motor snaps to attention with every touch of the throttle, revs higher (up to 7,000 rpm for brief periods) and, to our ears, sounds better. Put the two on a drag strip and physics predictably delivers the lighter, more powerful GT500 to the traps half a second and 7.4 mph ahead of the ZL1.
Specifically, that's an 11.9-second pass at 123.5 mph an impressive number, but not an easy one to achieve. Our best run was made using the GT500's adjustable launch control set to only 3,000 rpm to accommodate our low-grip launch surface. Also, the GT500's shifter protested aggressive 1-2 shifts, sometimes rejecting 2nd gear altogether a problem we've had when testing previous versions of the Ford Shelby GT500.
For its part, the ZL1 proved easier to drive in every measure. Its shifter snaps rapidly from gate to gate, encouraging the flat shifts Chevy engineers programmed its engine calibration to accommodate. By keeping the supercharger's bypass valve closed for 0.2 second when the clutch is depressed, boost remains peaked as the next gear is engaged, improving acceleration. What's more, its shorter 3.73 rear-end gear is less likely to produce the bog-or-boil scenario to which the Shelby is prone when not using launch control. The Camaro's clutch is also more easily modulated leaving the line.
But it's still slower. Our best pass was 12.4 seconds at 116.1 mph.
We managed, after several runs, to beat the ZL1's launch control, but only by about a tenth of a second to 60 mph, which arrived in 4.4 seconds (4.1 seconds with a 1-foot rollout as at a drag strip). At 4.0 seconds (3.7 seconds with rollout) the Shelby, again, was quicker.
The Basics
How It Happened
