General Maintenance & Repairs - Hard to start and tach not working
blacko2ws6
06-13-2012, 06:09 PM
i replaced the flywheel, clutch, and pressure plate and it all works great except when i try to start the car it will turn over just fine but will take about 7 seconds or so to actually start. along with this the tach stopped working. i check all of my connections into the transmission and they are all good. any help??
lt1pwr1
06-13-2012, 06:15 PM
Check your Cam sensor- you probably broke the sensor, or wires going to it, or burned them, etc.
hotrodth
06-13-2012, 06:27 PM
Crank sensor...or cam sensor. Good luck. Both parts are approx 50.00 each
blacko2ws6
06-15-2012, 03:06 PM
thanks, i read the codes and it was indeed the cam sensor, where is it located on these cars?
w06gto
06-16-2012, 07:15 AM
Behind the intake manifold, you need to take it off to replace the sensor.
