Generation IV Internal Engine - LSX 402 Callies OR Eagle? Same Quality or NO
Riggs 74
06-13-2012, 08:06 PM
I am rebuilding my LS2 after a rod bearing failure destroyed the crank. I am replacing the whole rotating Assembly with a forged unit and can't decide between the Callies Compstar crank and rods with Wisco or Diamond pistons bought from Texas Speed, Or an Eagles crank and rods with Arias pistons bought through my machinist.
I will be reinstalling The Trick Flow 225 heads and Camshaft, Hydraulic Roller Tappet, Duration @ .050 in. 238/242, Lift .595/.595. This is the Trick Flow LS2 head and cam combo that I installed on the motor before dropping it into my 74 Corvette. It worked really well on the Stock LS2 short block. http://www.summitracing.com/parts/TFS-K306-550-470/KitComboContents/
I am looking to end up with some where around 600 HP with the set up, I do not intend to look for or need any more power for this street car, so the HP shouldn't be a factor, but I do intend to run the car hard, as often as I can, so I want it to be bullet proof with in reason.
Any insight on the two brands, what is the better buy for this HP level.
Thanks,
Riggs
Azrael
06-14-2012, 06:36 AM
I think either will be fine for your goals. Generally though, I have always had the feeling that Callies was just a little bit better than the Eagle stuff, but that is subjective. Although I just don't see 600 hp in the combo...
Good luck with your build!
redtan
06-14-2012, 07:20 AM
At the power level that you will be at (600 at the crank, high 400s at the wheels) any of those brands will be more than fine.
When you start pushing stuff past 6-700 at the wheels is when you would theoretically need the higher quality brand.
Gray86hatch
06-14-2012, 08:13 AM
Callies finish work is way better. I have a eagle and will not use one again.
Tim
Ryne @ CMS
06-14-2012, 09:17 AM
here is what i have found with eagle stuff:
1: rod and main journal poorly machined (raise almost .001" towards the edges of the journal), requiring the crank to be turned, at that point you might as well have bought a callies crank....
2: Pilot bearing recess too large
3: freeze plug in the rear of the crank leaks oil, sometimes randomly..
Sales2@Texas-speed
06-14-2012, 09:40 AM
I agree with Ryne! The little money you save going to an Eagle crank you can easily spend making journals round, sealing the rear plug, etc! This is why you cannot buy a Texas Speed short-block with an Eagle crankshaft installed!
Reckless
06-14-2012, 09:48 AM
Agree with Ryne and Matt
87silverbullet
06-14-2012, 02:01 PM
x3 on this one.
I have an engine builder who will not order an eagle crank and if you bring him eagle stuff he will hand it back to you.
Jablowme
06-14-2012, 02:04 PM
not to put any brand down but eagle is crap hack and slash !
callies is #1 quality
id even use scat before any eagle stuff, once you have seen and measured all 3 you
will understand as well
hope this helps
Troy5061
06-14-2012, 02:34 PM
I have an Eagle Crank in my 383, no problems yet:burn:
Ive heard they don't measure up good but mine was fine, also heard they leak out of the rear plug but mines fine so far....and I have an auto so if it does its not as big of a deal as with a clutch being right there.
Pseudonym
06-14-2012, 03:05 PM
Callies is better. Everyone I have spoken to about crankshafts said the same thing.
Riggs 74
06-14-2012, 04:32 PM
Thanks Guys for the help, through my research I had found many negative post about Eagle, but none about the Callies brand.
I will be using Callies for the build.
Thanks again,
Riggs
xdanny510x
06-14-2012, 07:48 PM
Damn if i.wudve known that this happ end i.wudnt have bought one with that crank that yall had in stock back couple yrs ago lol... But no problems yet lol.
Sales2@Texas-speed
06-15-2012, 09:31 AM
The ones we did assemble with the Eagle cranks were fine....they would have either been round, or turned to make them round before assembling. No worries for you. This just makes life easier for us now.
eatlead
06-15-2012, 10:52 AM
LMAO!
Eagle would be just fine in your case as well as Scat rods. Its not the coomponents ( at this power level) its the builder and some builders just have fancy machines and no real knowlede of engine building.. but they have a fancy machine.. and spout off like they are an expert or something....LOL
negative comments about eagle are from inexperienced builders and guys who dont have the ability to machine properly and garage hacks
Yes Callies is better, you pay more for it. I would let your builder make your decisions for you, he is the one building it and it will come back on him.
I've seen the plug on a $1250 Callies crank leak as well...
Sales2@Texas-speed
06-15-2012, 11:05 AM
Has anybody in this thread said the Eagles can't be made to work? Nope. But why go that route and have the extra machine time and cost just to break even with what Callies can do out of the box?
87silverbullet
06-15-2012, 11:29 AM
Out of all the engines I have had over the years and I have seen and known about the build. I know of 3 eagle cranks that have snapped off the snout on N/A motors. 2 cranks from them were out and had to be turned to get them right. You shouldn't have to turn them new out of the box. I have used Lunati, Callies, and Manley crankshafts with out an issue and all were recommended by 3 different engine builders over the years.
Juicedh22
12-13-2012, 05:07 PM
This confuses the hell out of me... I can go onto your website right now and get a rotating assembly with an Eagle crank... in fact all the "base prices" are based on the eagle crank... So you either offer it, but dont sell it but still show an advertised price with it... or you do in fact sell it... (granted that is not an assembled short-block, but still seems two sided)
It gets even more confusing when you can find posts like this (though granted, it was from 2008)
We have run both cranks with great success. I think more than anything it comes down to a personal preference and going with a well known product. We run Eagle cranks in probably 70% of the motors we build. We have made over 1200 HP with both and have never had a failure from either one. Feel free to give us a call if you have any questions or what way you decide to go. We have both on the shelf and can get you setup with smokin' deal! :)
Don't get me wrong, just from "opinion" and found snout failures, it sounds like the callies is a better piece... I was doing searches to confirm, since I have a $600 gift card for amazon, and the only crank on there right now is Eagle... but I felt compelled to point out the confusion in what you are saying, vs what your website shows...
I have used Eagle cranks for yrs but always bought there blems that were turned once here in the states. They make them in China where the machining is inferior. Thats the way to go and cheaper if you choose Eagle.
I have heard even some of Callies is now made in China!
Quick Carl
12-14-2012, 07:33 AM
Callies and move on. They are all machined here and the journals are round and straight.
Snyper
12-26-2012, 10:56 PM
My callies crank had this problem. I could not for the life of me figure out what was leaking...to be honest after visual inspection, it looked to be perfectly sealed..however whenever the car was on it would leak. I had to replace the plug and seal it up.
Jontall
12-27-2012, 05:24 AM
I think the Compstar products are forged in China and machined here in the USA. I don't trust anything made in China and wouldn't buy or run it. Callies Dragonslayer cranks and ultra rods are 100% forged and machined in the USA and that's what I would buy.
RezinTexas
12-27-2012, 06:43 AM
I have no experience with Callies or Eagle cranks, but my K1 4" crank was ready to go out of the box. Main journals were 0.0001" OOR, rod journals were up to 0.0003" OOR, and rise towards the end of the rod journals was limited to 0.0001".
KRAZY K 2000 TA
12-27-2012, 09:27 AM
i had to have my eagle crank machined brand new out of the box,Engine Builder did it for free after he contacted the manufacturer,figured he was just paid by them instead of sending it back.
87silverbullet
12-27-2012, 09:30 AM
You are correct. Don't count out the compstar crank though its still a tough piece.
RTBenny
12-28-2012, 06:11 PM
Got an Eagle crank with Wiseco pistons in my car. No issues so far. But I have heard Callies is superior. At 600 flywheel horsepower, I think either will hold up well.
Blackpanther99
12-28-2012, 08:40 PM
Callies is the way to go!
Mr Monaro
12-29-2012, 02:16 AM
How long has Eagle been made in China for its sad its all China.
cheers
joe
Jon@BruteSpeed
12-29-2012, 08:07 AM
Callies Compstar line is forged in China, but machined here. The rest of their products are made here. My brother used Compstar the majority of the time back in the EPP days, no problem on the boosted builds they did then.
I am in the process of putting together a boosted LS3 and went with Compstar as well.
