New LS1 Owners - Newbie Tech - Cleaning fuel injectors
View Full Version : Cleaning fuel injectors
Alberto v05
06-13-2012, 08:58 PM
I want to clean my fuel injectors but I'm just making sure what brand to use is there a specific brand to use on my 1999 z28 or does it not matter what brand to use like stp fuel injector cleaner? Thanks ls1tech
ssteven
06-13-2012, 09:19 PM
Seafoam
BlackScreaminMachine
06-13-2012, 09:38 PM
Send them to a shop, can sonic clean them best way.
RPM WS6
06-13-2012, 09:53 PM
If you just want to dump something in the tank for a minor cleaning, I've had great luck with Red Line SI-1. If they are really bad, they may need a bench cleaning.
beyonddisturbed
06-13-2012, 10:47 PM
I like to do a bi annual seafoam dump in a tank of gas. Keeps em clean
Alberto v05
06-13-2012, 10:49 PM
yes, i just want to dump something in the tank. So the Red Line is what i should get?
RPM WS6
06-13-2012, 11:40 PM
Some people like Seafoam. I like Red Line for this task. But you could try them both on different tanks if you really wanted to.
wicked383lt1
06-14-2012, 12:27 AM
This right here... http://ls1tech.com/forums/general-maintenance-repairs/534376-how-seafoam-your-car.html
DeLaRosa25
06-14-2012, 02:50 PM
I seafomed my dads 00 TA and it didnt go well haha, but worked great for my 94
My 98 I use vavoline cleaner. 2 part system, just like seafoam went through booster..then second part gas tank..works great
2win_SS
06-16-2012, 04:19 AM
Does anyone know a good method to clean out fuel injectors when they are out? I have a pair I bought USED and I would like to clean them out... And if I have to send them into a shop how much does it usually cost?
bene
06-16-2012, 04:47 AM
FIC will clean them (our sponsor) and they will replace the O rings as well if they need be.
The cost is like $125, IIRC.
TomXTC
06-16-2012, 05:11 AM
It depends on how dirty they are. If a in tank cleaner is not enough I have had good luck with using an Autovac cleaning system found at some auto repair shops which runs a closed loop through your fuel system for a period of time with cleaners and I think a big step above putting something in the tank but less than removing them for a cleaning. I use Techron on a regular basis when I can but it on sale 2 for 1 to help keep them from getting too bad in the first place. I also ran just a bottle of Techron through one of my motorcycles I had left out all winter due to a surgery and it has 4 carbs. One tank of that and it was idling better than ever and did not need the choke on as long during warm up. If that is not enough then many people use the Seafoam.
2win_SS
06-16-2012, 05:20 AM
Thanks for the quick response Bene. I'll look into it.
waxenate
06-19-2012, 03:17 PM
Go on you tube and search for homemade fuel injector cleaner......I did it and worked great.
777
06-19-2012, 04:20 PM
http://fuelinjectorconnection.com/shop/viewcategory.php?groupid=79
They're a sponsor and seemed really great when I inquired about cleaning & re-sizing injectors.
lebedin8654
06-20-2012, 01:24 PM
+1 I have had good luck with sea form and Lucas
NC98Z
06-20-2012, 01:52 PM
Lucas.
