MackTruck49
06-14-2012, 01:34 AM
Hey guys im having an issue with the throttle/idling/stalling sometimes on this car...when i push the clutch in sometimes the throttle stays at the same rpm or climbs a little till i shift into a higher gear and it brings the rpm down with the road speed. say if sometimes im pulling into a parking spot while turning the rpms get real low and it stalls(while coasting into a parking spot, and turning with the clutch depressed) sometimes also the idle surges but not always, do we have any ideas of what this could be?
the car has 85mm throttle body, and spacer. 85mm fast intake manifold, dyno tuned and full exhaust system...gm hot cam as well.
