Pardon my stupidity....
....but whats the easiest way to find TDC of the compression stroke on the #1 cylinder with the timing cover installed? Im doing a head swap so the timing cover never came off and I need to find TDC so that I can torque the rocker arms in accordance with the service manual.
Thanks.
Thanks.
understood, but I need to position the motor manually prior to bolting on the valve train in order to properly torque the rocker arms, so at this point, none of the valves are open, regardless of piston position as the rocker arms and push rods havent been installed yet
When you install pushrods/rockers and loosely snug them down you will see which valves are being opened.
You can tell TDC by having the spark plug removed and seeing if the piston is up.
You can also pull the spark plug, place a paper towel in the hole and when it blows out it will be on the compression stroke, that's a good method when working by your self, if you have a friend, they can just put their finger over it and wait for it to blow back.
