Carbureted LSX forum - approx. Hp Tq
schwanman66
06-14-2012, 09:42 AM
I'm trying to get a baseline for hp/tq on my current project. Hopin someone has an idea where I'd be. I have a 2006 lq4 with 799 heads(stock with upgraded springs) for the cam which is a 220/224 w/ .575 lift 112 lsa. intake is a performer rpm with center milled like an airgap with a holley dp hp carb running through a built 700r4 with a 3000 stall. 3:70 gear stock 9bolt rearend and car is a 89 GTA trans am. where should I be to the wheels currently? would I be able run low 11's with this setup on drag radials?
schwanman66
06-14-2012, 10:56 AM
anyone?
ZONES89RS
06-14-2012, 05:55 PM
Should be about 420ish to the ground and the torque may be a bit higher with that cam. Might be even more, you did not list headers and exhaust or what size carb.
schwanman66
06-14-2012, 09:17 PM
I'm using hawks stainless 1 3/4 with 3" collectors. What kind of 1/4 mile time would you guess with this setup? has no ac, alum driveshaft, subframe connectors, lower control arms, panhard bar adjustable. stock ws6 springs all around. no sway bar up front. removed rear seats, carpet. has t-tops. fiberglass hood. removed bumber supports, along with fog lights, I've never weighed yet, just guessing 3400 with me, I may be off some. My goal is low 11's.
schwanman66
06-14-2012, 09:19 PM
2.5" duals to axle exhaust wise with a 750 double pumper holley hp carb
speedtigger
06-15-2012, 08:10 AM
It is going to depend a lot on the weight of the car, but if it is 3400 with you in it, then you might expect mid to high 11s if everything is right.
onefast84
06-15-2012, 08:24 AM
I second the mis to high 11's! similar to my setup! It wont be very hard to get it to go faster!!
schwanman66
06-15-2012, 10:44 AM
Thats what I was thinking also. I'm talking with Pat G on a custom grind cam, hoping maybe I can get closer to my low 11 sec goal with a little more cam.
speedtigger
06-15-2012, 12:55 PM
There is no magic cam that will make your combination make 50 to 70 more horsepower. Maybe 10 to 15 more horsepower from a really well designed custom cam on your combo. The intake and heads are your limiting factor.
You have a combo that will have great drivability and all around torque and power. If you are aiming for a certain performance number or are going racing, I think you should be thinking Victor Jr., better heads, more compression and a higher stall converter. Its all about the combo and just a cam is not gonna do it alone.
schwanman66
06-15-2012, 01:39 PM
I completely agree with you on there being no "magic cam". But like you said, the combination of the parts together. The cam I currently have may not be the right one for the current combo. I originally bought this camshaft for a 5.3 swap, but ended up with a 6.0 before it was all said and done. I knew up front the 220/224 was a small cam, but made good torque and was a good street cam.
speedtigger
06-15-2012, 01:58 PM
That cam is actually a very good cam for your intake and converter choice. I had a Comp 222/224 .556"/.568" initially and swapped it out for an EPS 226/234 .598"/.612". I gained about 5 to 10 HP with the swap and all of that was on the top. The car did not go any quicker in the 1/8th mile, but had 1 more mph.
My car went 7.40s in the 1/8th and 11.70s in the quarter with the 222/224, Performer RPM, 2800 converter and a 750 Holley. My car is 3725 with me in it but I have CNC ported LS6 heads. I would say the heads are probably about an even trade for our weight differences, so I am guessing your car will run about the same numbers.
The intake your are running has pretty small ports internally, so it kind of limits the high rpm breathing and potential, but has amazing torque down low and in the midrange. That is why I say just a cam won't do it. Now if you wanted to change the intake and torque converter, then I would definitely go bigger on the cam if you want to run low 11s.
schwanman66
06-15-2012, 02:45 PM
Thats good information! With the ported ls6 heads, did you do any porting to the rpm manifold to aid breathing there? I know milling the center seemed to help in the 4000+ rpm on my setup. I'm guessing a 1" spacer would also do the same thing, I just didn't have the hood clearance. I've thought of doing some pocket porting to the RPM manifold, I just wanted to see what it ran first without. The Cam suggested to me by Pat G was similar to the new one you changed to.
ZONES89RS
06-15-2012, 02:54 PM
11.70ish.
speedtigger
06-15-2012, 03:04 PM
I tried all 3 styles of spacers on the dual plane. There is a thread in this section somewhere on it. None seemed to make much difference at the track. You can only reach so far into the dual plane port to enlarge it. The real restrictions are past the bend and there is no way to enlarge it without cutting the intake apart. The Performer RPM just is what it is. It has great torque and midrange power. I had a 1.62 60' time with it using my 2800 converter. That is pretty impressive. You will be impressed with the torque of your motor. But, if you are going racing and trying to make big numbers, it just will not flow enough air. But, unless you are going bigger with the converter, it is a great intake choice.
If you really want a bigger cam. I think you could go as far as something like 230 duration @ .050' and your car will still run great with that intake and converter. If you switch to a single plane intake with a 230 @ .050" cam or bigger, you will want a higher stall converter.
