Ryan@Lingenfelter
06-14-2012, 04:43 PM
The Lingenfelter High Flow Cold Air Intake for the supercharged Camaro ZL1 is the first upgrade every ZL1 owner needs to install. The Lingenfelter ZL1 air intake is a complete easy to install system that will boost engine performance by reducing air intake restrictions and with its unique design blocks hot air from your engine compartment by sealing to your hood. This is the same air intake system that was on the Lingenfelter ZL1 that was the first to dip into the 10s in the quarter-mile and the first ZL1 to go over 200 MPH with a 202.67 mph run. The Lingenfelter High Flow Air Intake uses a lifetime washable oiled filter to protect your engine without restricting airflow.
The Lingenfelter ZL1 Air Intake kit includes:
- Air Box designed to prevent hot engine compartment air from entering the engine
- Black powder coated aluminum air box adapter tube incorporates the stock MAF
- Utilizes a large six inch air filter mounting flange
- Heavy duty black plastic inlet air duct
- Installs easily using factory mounting points
- Will not cause SES codes and requires no tuning
- Lifetime washable oiled filter
Picture shows unpainted prototype tube
ZL1 air intake (http://www.lingenfelter.com/mm5/merchant.mvc?Screen=PROD&Product_Code=L650162012&Store_Code=LPE&search=zl1+air+intake&filter_cat=&PowerSearch_Begin_Only=&sort=&range_low=&range_high=)
Ryan
Ryan
