running secondary injectors on stock PCM, will this work?
so I had an idea about how to possibly run a set of piggyback injectors using the stock PCM and such, and not sure if it will work or not. say for each injector, you tapped the switched ground signal from the original injector up to the secondary, but then tied the positive feed wire of all of the secondary injectors on something like a window switch or boost switch. this way they will only get power at pre-determined boost or rpm levels, and the pulses will be in time with the injector they are piggybacked off of. I'm sure some creative tuning may be involved in being able to compensate for the sudden increase in fuel supply. but it's just a thought, wanted to put out there and see if anyone had any ideas on it. or if it is already being done
Wont work. The factory injectors are wired that way already. The PCM provides a ground for the injectors and completes the circuit. Wiring a second set would overload the drivers in the PCM. The only way to make that work is to piggy back the signal off the stock injector circuit to an injector driver like the AEM that has it's own control circuit. Doing that though would be just as easy to buy a bigger set of high Z injectors.
well to my understanding it just pulses a ground signal and there is no real load there. the power would be provided by the external source. idea was inspired by my friend suggesting me to piggyback a set of factory 36lb injectors from the supercharged 3800 on with my stock injectors on my 5.3 for being able to support boost
I'm working on something with the cobalts, but will be looking into it for my trans am also.
I know hahn racecraft had something out for a while to control a 2nd set of injectors (non sponsor so no link). it was called the port fueler if you want to look into that, pretty sure it ran off a map signal and had its own tuneable injector map
DIY Autotune has or had, haven't looked lately, a driver box for the MegaSquirt to run different injectors. Not a resistor box.
It was only a jumper to make it run high or low Z.
Piggy back that box onto the stock setup and drive as many injectors and boxes as needed. The box only uses the PWM signal and has it's own power cable since the injectors are wired to the box.
All the injectors will have the same PW signal. The transition to the extra injectors is the hard part of tuning.
Use a switch of your choosing to control the signal to the driver box. The LT5 used this scheme from the factory IIRC. If you dig up the wiring diagram you'll see the relay. It had a 4v head so gm used a relay to control an air valve and the respective injector to turn half the induction sys off for low power driving. hmm... I'll have to dig up the ECM program hac for that car and see what they did for the fuel.
You can run high z injectors on low z drivers ok, but not the other way around.
Adding a second set of injectors to a high z driver will over heat the driver and burn it out.
