New LS1 Owners - Newbie Tech - JP Double Roller Timing Chain
View Full Version : JP Double Roller Timing Chain
Rtzracer
06-15-2012, 08:32 AM
Anyones experience with the JP double roller? Pros/Cons?
Sales2@Texas-speed
06-15-2012, 09:39 AM
We've run a lot of them under the N-Motion name (N-Motion used to rebox them, now they just send them in the JPP packaging). They are nice sets that don't break the bank. Torrington bearings, adjustable, tough....
thatoneguybriz
06-15-2012, 01:27 PM
Does a JP double roller interfere with the stock oil pump housing or timing cover?
Rtzracer
06-16-2012, 12:41 PM
From what I've read, double rollers require some modding on the timing cover. Unless you buy a comp timing cover built for the double roller. Still deciding on which double roller to buy; Comp, SLP, JP.....?
+badss+
06-16-2012, 02:26 PM
I'm using a JP dbl roller on my engine you have to use a dremel to remove a little bit of material from cover to fit not real hard.
I8UR4RD
06-16-2012, 05:33 PM
yeah that is what AES uses on their motors. I am working on my cover right at the moment.
TransamGCS
06-16-2012, 07:12 PM
if you get the SLP double roller SLP oil pump combo you dont have to grind the cover or use shims
conan
06-16-2012, 09:03 PM
I'm running a rollmaster double with a ported LS6 pump. Oil pump is shimmed and it clears the stock timing cover.
Rtzracer
06-26-2012, 10:34 AM
So, the SLP double roller and SLP oil pump do not require timing cover modificaitons?
TransamGCS
06-26-2012, 05:31 PM
correct
Rtzracer
06-27-2012, 01:27 AM
Thanks Trans for the info. That will save me a lot of headache.
