What is it Worth? - can someone help me??
View Full Version : can someone help me??
02mmmz28
06-15-2012, 06:53 PM
i am trying to figure out why i cant give away such a clean low mileage camaro... im looking to get $11,000 for the car this is wat it has...let me know if im out of my mind or something...
2002 Camaro Z28
49,652 miles black on black hard top
Engine:
stock short block
LG G5X4 cam specs can be given by lg
comp cams lifters
comp cams behive valve springs
comp cams locks
comp cams hardened push rods
factory LS6 intake and throttle body
smooth bellow tube
slp lid with ram air upper box
ford motorsports green top 42lb injectors
american race headers stainless steel long tube headers and off road y pipe
hooker cat back with black powder coated quad tips
160 degree thermostat
Transmission
t 56 6speed with factory hurst shifter
monster stage 4 clutch
adjustable master cylinder
new slave cylinder
Rear
moser 12bolt
4.10 gears
31 splines axles with factory wheel studs
suspension
umi 35mm front sway bar
umi 22mm rear sway bar
umi adjustable torque arm
umi on car adjustable panhard bar
umi double adjustable lower control arms
relocation brackets welded to rear
umi weld in sub frame connectors
rims
oem factory wheels (snowflake wheels) fronts and rears with drag radials
oem factory zo6 wheels with bfg radials 275/45/17 & 295/35/18
rippinls1
06-17-2012, 07:50 PM
sounds to me like you got alot into it and its got loow mileage; However you rarely get $OUT what you put IN$ on a car... most of the time at-least :/.... if you follow me...but if they know all that it has, not a bad price IMHO... if i were you and i couldn't get what i wanted for it, i would hold onto it until you did or you'll regret it...b.c sooner or later someone who knows what they want will pick it up from you. especially with that mileage.. the $ can only get better from here.. idk if that helps.. glws!
Daniel76
06-17-2012, 09:21 PM
I don't think it sounds unreasonable at all. I sat on a 63k mile 2000 SS for nearly 5 months before the right buyer came along. I think the car is worth what you're asking for it. Money is tight right now and an $11k toy is not in a lot of peoples budget. Just be patient.
