Gears & Axles - will 342 rear from a v6 work on my ws6
Leeroyws6
06-15-2012, 09:35 PM
i got a local guy whos got a 99 v6 camaro 5 speed parting it out. will the rear end bolt right up to my 2000 ws6? i got 2.73s now and im trying to go with some bigger gears.i believe the camaro has 3.42s. im not worried about my abs.and i have no traction control in my car.just wondering if the rear is a 342 and will it bolt right up?
that way i can put the 2.73 gear on some stands and work on it while racing the 3.42 gears
transamtom
06-15-2012, 10:13 PM
Yes but you might want to check if its a posi,most V6's got a peg legger.
If it has the Y87 sport pkg then you got 3.42's with a posi.
Leeroyws6
06-16-2012, 06:10 AM
Ok thanks for the info.hopefully it has that roo code.should I look on the door?
Cape T/A
06-16-2012, 11:17 AM
the rpo code is on the door of every car and will say what rear end it came with from the factory.
Cape T/A
06-16-2012, 11:18 AM
the 3.42 gears will throw your speedometer off also, so be aware of that.
