Does a 6.125 rod on a stock stroke extend the piston further out the deck?
Old 03-31-2004, 12:36 PM
BB
BB's Avatar
Default Does a 6.125 rod on a stock stroke extend the piston further out the deck?
Does a 6.125 rod on a stock stroke extend the piston further out the deck? If you go from a stock length rod to a 6.125 one what are the effects? I know it means that your piston will stay at TDB/BDC a tad longer and I think you get less side to side motion. But what about things like extending out the deck more than the stock one does?
Old 03-31-2004, 01:22 PM
Super Moderator
Reckless's Avatar
Yes. If you want that rod length you need custom pistons with the pins moved higher up into the piston.
Old 03-31-2004, 05:58 PM
BB
BB's Avatar
Ah, right. I forgot about that thanks!
