O Holy P
06-16-2012, 05:52 PM
Excellent condition and well maintained. Always serviced with Mobil 1 Racing 4T 10w40 every 2500~3000 miles, oil AND filter. Only use OEM Suzuki oil filter. Bike runs flawlessly and has a ton of power. Comes with solo cowl (hump), and rear seat which has been reupholstered to match the front and the rear grab bar which is not currently installed. If you see this bike in person you would never guess that it had more than 5,000 miles on it. I take very good care of any thing I own and this bike is no exception. Always stored inside under a cover and always kept clean and forks wiped down after riding in any rain. I have performed all of the work myself with the exception of the cylinder head porting, valve job, and cylinder boring. If you have any questions give me a call at 386-882-2603 ask for Patrick. You will not be disappointed with this Hayabusa.
Engine:
1397 kit which dyno'd 191rwhp/113rwtq in 98 degree ambient temp. inside a trailer. I'd say around 200hp in good weather. (have dyno graph). The 1397 has approx 3k+ miles since installed.
ECU reflash tune done by Walter Sprout in Jacksonville, FL
Has ECU re-flash harness installed for future use.
Mahle Pistons & Rings (84mm)
Ported head (have flow sheet)
Cometic Head Gasket
Dual Intake Cams w/ adj. sprockets...have been degreed.
Air Box Mod w/ BMC Filter
PAIR removed.
Also have ram air tube seals (not installed)
HD Clutch Springs & Back Torque Eliminator
Factory Pro Shift Star Kit
Yoshimura 4-2-1 full stainless steel exhaust system w/ carbon fiber dual-exit can.
Chassis:
Dunlop Q2 tires F&R with about 50~60% life left.
Sintered Metal brake pads (similar to EBC HH)
Steel Braided Front Brake Lines (black)
Polyurethane Cush Drive
Fork Seals replaced around 18.5k miles with new seals AND wipers from All Balls
Helibars
Pro Grip 719 Grips
Throttlemeisters Throttle Lock
GI Pro Gear Indicator (blue # read-out)
Tobin/New Image seats (front & rear)
Also have solo cowl (hump) that has been clearanced for the grab bar (currently not installed but I do have the grab bar)
HID 55w 5000k low beam headlight with DEI 528T delay timer so it does not flicker on and off when starting the bike
Clear Alternatives LED integrated rear tail-light
Tripage LED turn signals installed into rear pegs (amber in color)
Zero Gravity Double Bubble CLEAR windscreen
3BR USB port for charging phones or accessories
Speedohealer V4 with Top-Speed recall function/button
Fresh Battery, less than 6 months old.
Mirrors have been painted to match bike (Suzuki color code YAY, black with blue pearl)
Original tool kit.
The only bad thing about this bike is that it was tipped over once and has a few scuffs on the stator cover and LH fairing. Hardly noticeable unless you get down and look for it.
Clear & Clean title in hand.
Asking $7,700
HD Video Walk-around: http://youtu.be/kFRzznTvZl8
Engine:
Cometic Head Gasket
PAIR removed.
Chassis:
Helibars
Pro Grip 719 Grips
Original tool kit.
Asking $7,700
