LQ4 in 2005 Silverado
Old 06-17-2012, 08:17 AM
silverado2005's Avatar
Default LQ4 in 2005 Silverado
I have been told to put a set of LS2 heads and a cam from 02-04 Z06 Vette.
Does this sound good? How much would it raise the compression?
Any help would be appreciated.
Old 06-17-2012, 11:35 AM
13 Second Truck Club
726.0chevelle's Avatar
check out performancetrucks.net at the top of the page. It would raise the compression from 9.4 to somewhere around 10.2 to 10.3. I wouldnt use a ls6 cam id get one a lil more truck friendly like a comp 265 or comp 269 if you wanna stay small.
Old 06-17-2012, 01:03 PM
could I still use 87 octane with the higher compression?
Old 06-17-2012, 02:13 PM
parks450's Avatar
It's not ideal but yes you could, and the ls6 cam would be fine, it's a pretty mild cam.
Old 06-17-2012, 04:45 PM
If your not wanting to run the higher octane fuel i wouldnt switch heads. Your tuner is just going to put less timing so that negates the purpose.
Old 06-17-2012, 04:58 PM
Darkman's Avatar
It can be set up to run either octane fuel - the computer will adjust to the lower octane as needed.
Old 06-17-2012, 06:38 PM
I appreciate all the help. Ultimately I will be pulling a camper with this truck so I want good low in torque. I don't mind using a higher octane if needed but would it be better overall to just change camshaft and get a good tuned PCM? I plan on a better muffler and change the factory air inlet to some degree.
I was told a little higher compression would actually be more efficient on mileage when not towing.
Thanks
Old 06-17-2012, 06:48 PM
Darkman's Avatar
Compression is helpful in terms of torque/power and gas mileage. Although the heads will increase your static compression the cam will pressumably take back some your dynamic compression. Given the torque a stock LS6 puts out, I don't think you will have a problem given your displacement. You should get a tune, but the computer can handle differences in fuel octane such that you can run 87 octane much of the time and switch to higher octane when performance is needed. A stock LS6, for example, can run either octane.
Old 06-17-2012, 07:24 PM
Any recommendations on where to get PCM tuned? I was told to check out wait4me performance ?
Old 06-17-2012, 07:31 PM
Darkman's Avatar
I got a mail order tune from Wait4me for my LS6 once and it was satifsfactory. I have since moved on to a hands-on tuner and I believe that process yields better results, but which one to use depends on where you live.
Old 06-17-2012, 07:45 PM
Tennessee ???
Old 06-17-2012, 07:56 PM
Darkman's Avatar
I don't know any tuners in Tennessee. You might want to post in the regional forum for Southern Members also.
Old 06-17-2012, 08:16 PM
Thanks for all the help. Unless there are anymore suggestions, I will go with LS2 (243) heads and the LS6 cam.
Old 06-17-2012, 09:33 PM
gjohnsonws6's Avatar
Spend some time on performance trucks, look into the trucker cam and long tubes. From what I understand the ls6 cam is not a very good choice. I would put a post in there and then make a decision.
