Dynamometer Results & Comparisons - Engine Dyno Results: LS3 427 639hp/610tq
firefighter813x
06-17-2012, 10:25 AM
Had a LS3 427 built... see specs below
*Posting this for informational purposes! Engine was dyno'd at Westech in So Cal*
I'm in Iraq and don't have the graph with me... it has a great torque curve. A bigger cam would make more power but I was looking for all around usable power instead of peak numbers.
All forged internals @ 11.2:1 compression
Mast Motorsports "Black Label" med bore LS3 heads
Comp LSL 239/247 .624"/.624" 114 cam
stock ported LS3 intake
Ported LS2 TB
LS7 injectors
firefighter813x
06-17-2012, 10:23 PM
Anyone else have a similar build?
venom ws7
06-18-2012, 01:54 PM
Great numbers with ported stock intake and tb.
Congrats man going on the C6?
N2OBaby
06-18-2012, 03:02 PM
Ported LS2 TB
LS7 injectors
Is that 4.070 bored stock block or a resleeved 4.125 bore block?
The output at the flywheel is very good.
I have a resleeved LS7 at 438ci (4.1" crank) with 12:1 on stock LS3 heads with lightweight s/s valves, stock LS3 intake, 92mm TB, mid length headers and tiny 235/242 .600 lift 115LSA cam. The headers were certainly choking it up but it made 530rwhp/510rwtq. The power falls flat at around 6K RPM and redline is 6600rpm. Mild road race motor.
firefighter813x
06-19-2012, 12:15 AM
Yeah, when I get home I'll be putting it in the C6!
I was really thinking of swapping out the 6L80e for a 4L65e via RPM or Race Proven Motorsports...the block is a stock bored 6.2 LS3.
gnx7- Hmmm... I would love to see about 530 at the wheels but I've been heartbroken in the past with stalled autos. See sig with my old '98 fbody. I also have 2" American Racing headers that will help this thing breathe!
Overall, it should be a fun N/A car that might go to the track once to hopefully get that 10 second time slip. The car ran a best of 11.3x at 123mph with AFR 205's and a 224 cam, stock intake, ARH 1 3/4 and Corsa Sports on the stock converter with 17" Hoosiers.
Frans96SS
06-19-2012, 03:16 PM
Deff a nice setup. Let me know if you have any questions about the swap. Stay safe over there.
jmilz28
06-22-2012, 01:19 AM
Who spec'd the cam? You need a FAST 102/102 combo...
WKMCD
06-22-2012, 06:31 AM
Firstly, thanks for your service! :usa:
My 427 is a Darton sleeved LS2 build. 4.125x4.00. WCCH Stage three L92 heads. Cam is considerably smaller than yours. "Modified" FAST 102 and a Nick Williams 107mm TB.
Engine dyno numbers were 656/615 as I remember.
RW numbers in sig. This is a VERY mild build that I can cruise a 600RPM in 6th gear and pull away cleanly.
Build thread.
http://ls1tech.com/forums/generation-iv-internal-engine/662314-l92-dynojet-numbers-plus-plan-b-c-d-e-f.html
http://i54.photobucket.com/albums/g93/WKMCD/corvettepicphil5.jpg
It's in this:
http://i54.photobucket.com/albums/g93/WKMCD/corvettepicphil1.jpg
Really Nice torque!! I'd rather have more weight with a 4L80E than mess with 65e stuff, even with the Billit 6 pinion planetary your still limited somewhat IMHO
firefighter813x
06-23-2012, 08:50 AM
The Fast on the LS3 is a waste of $. The cam in an "off the shelf" Comp cam.
jbhotrod
06-24-2012, 11:40 PM
Why go with LS3 heads over LS7? Wouldnt the LS7 heads flow better and make more power? Just curious...
Spellbound
06-25-2012, 12:51 PM
My Girlfriend has a LS3 based 427 with Trick Flow 230's and a ported Fast 90 and a 247/251 cam and it put down 530ish rwhp with the converter locked.
firefighter813x
06-26-2012, 06:57 AM
Damn. Marry her.
Where in Nor Cal? I'm from Vacaville.
I can't wait to see what mine puts down on the dyno. Unfortunately it will be at least a year or so...
fatmat80
06-26-2012, 10:28 AM
looking forward to seeing what you put down as well..
Be careful over there!!
Spellbound
06-26-2012, 11:10 AM
Damn. Marry her.
LOL, everyone says that.
Sacramento.
