Drag Racing Tech - 4L80E who's running one?
djsanchez2
06-17-2012, 03:15 PM
Picked up a used 2002 4L80E last night. I have a few questions....
It has approx. 25K miles on it, so i doubt it needs a rebuild. I've seen alot of people simple toss on a TransGo HD-2 kit and run it as is.
What mods do you suggest before i toss it in, if any?
Who makes 4l80e to LS1 converters?
Who makes a T/A relocation/4l80e mount?
Thanks in advance for any replies. The help is much appreciated.
It will be going behind a LQ4 and be backed by a 9" for what it's worth. **Edit** Change of plans, we decided to go with a 9" instead. Got a great deal on a 35 spline locker third member.
mike13
06-18-2012, 09:05 PM
Jake's has a shop that builds converters for him, Circle D also does them. BMR makes a crossmember.
+badss+
06-19-2012, 03:38 PM
bmr and mwc make the crossmember, circle d,yank and a few others make the converters. im personally went with lashway motorsports builder tcs they make them for other trans builders also.
89ROC-Z
06-19-2012, 04:17 PM
How about FTI or PTC for 4l80e converters? I have a 80e sitting in the shop, just waiting to for the 60e to go lol
djsanchez2
06-21-2012, 04:16 AM
Ok here's another think to think about....
Since the 80e has a softer 1st gear than the 60e.... should a short arm be used to hit the tires harder? Both a short arm and long arm set-up come in at around the same price so that removes price from the equation.
gator's 99TA
06-21-2012, 09:47 AM
I love my FTI converter. I have never met anyone that was unhappy with theirs. Call them up.
mike13
06-21-2012, 10:25 AM
TCS also builds converters for Jake's.
+badss+
06-21-2012, 12:09 PM
yep and others lol.
djsanchez2
06-25-2012, 08:49 PM
So ttt with this one.
I have the install part and converter figured out. Now im stuck on the Torque Arm, I am leaning toward a short arm for packaging reasons. Would that be a wise choice for a car that will probably never see a 9 sec pass?
I'm aiming for mid 10's on spray when it's all said and done. For the time being anyways. :lol:
RARON455
06-26-2012, 12:31 PM
I have always heard with a street/ strip car to go with a long arm.
djsanchez2
06-26-2012, 01:33 PM
It will see street driving 5-10%, if that. It has been sitting for over a year, since I got a DD. The only driving it will see is when the wife wants to go to the beach t-tops off or when en route to a race/track.
So i guess that answers my question.
ssvert99
06-27-2012, 09:23 AM
Short arm will serve your purpose very well, not to mention the long arm combined with the 4L80 trans is extremely tight at the trans.
Give me a call... I have the crossmembers, torque arms, and rearend for your project. I personally have owned the same combo you are going with here and can give you all the insight needed for the project, and a great deal on all the parts.
NOS LS1
07-17-2012, 09:47 PM
I will be running a 4L80E soon.
I will be going with the Midwest Chassis crossmember & Torque arm mount with driveshaft loop... Lowered version so i can run a large Diameter 3.5" Cat back system.
I have the Midwest Chassis Short Torque arm / Fab 9 in my 98 Camaro & it Rocks !
Great Fabrication work over at Midwest Chassis.
PCM For Less makes a 4l60e to 4l80e plug & play harness.
Fbodyjunkie06
07-17-2012, 10:49 PM
I loved my 4l80e and used FTI on both of my 80e converters in my turbo car and my current TH400 nitrous converter.
Greg will take great care of you and your converter to get it right the first time. Never have had to send any of mine back to him.
