Eastern Members - Looking at D-1 Pro charger
View Full Version : Looking at D-1 Pro charger
chknhwk01
06-17-2012, 05:37 PM
Thinking about putting a D1 Pro charger on my WS six.. With twin intercooler's.. Can anybody tell me about these D1 Pro Chargers?? Thanks
My84Z
06-17-2012, 06:20 PM
They supa dupa da air into ze engwin! Can u feel it wareorz!
popo8
06-17-2012, 11:41 PM
Hahaha..... thats a FLIP.
chknhwk01
06-18-2012, 06:47 AM
Ordering my d-1 twin intercooler, Pro charger today and a methol kit
hopeing to have my car back in two weeks yeah.. And they will tune it too.
Will let you know the horsepower rating is two the wheel and torque.. go fran
tektrans
06-18-2012, 06:54 AM
:jest:
daz fun nies kNo 1 LaFf wit aLl mize D1
feEL da paNe loOk mie tAilLites biAtcEs :D
BlackScreaminMachine
06-18-2012, 07:13 AM
I had researched this a good bit back a number of years ago. Back when I had disposable $$$. The only / main thing was that I would going to opt for the front mount intercooler vs the twins. From what I had researched they are adequet but the FM was considered optimal.
Only other issue was the D1 was great for "future power" but basically I could pop the motor as it stands and doing nothing but adding boost so then started the list of the more cubic inches, forged internals, heads, and so on and so forth and it soon became a 20k investment and I had to back of and be reasonable.
chknhwk01
06-18-2012, 01:04 PM
can u buy the fm by it seft? so what u thing ,a 370cins d-1 or pc1. thanks
blackscreaminmachine...
06-18-2012, 02:17 PM
The only time I would ever consider a Pc1 was if the car would never go beyone stock cubes, no internals and would never be re used on a "future LSx" motor.
The FM at the time was a option from Exotic Perf Plus or Brute Speed when Bob was involved, they offered for some $$$ more a FM vs the twins. Not sure if its a "pro charger" option as I gave up that dream after getting sick with cancer but I would think any good aftermarkt unit that fits 4th gens and just some new piping. Some minor cutting if I recal and you lose your fogs.
My84Z
06-18-2012, 03:28 PM
A d1 is fine on a stock motor it's all in boost levels and tuning. My suggestions would be get a single fmic and methanol. If this is the stock bottom end 10lbs of boost is more then enough
chknhwk01
06-18-2012, 08:22 PM
Thankz for the info... WE CAN DO THIS...
mikep2002
06-18-2012, 09:16 PM
Do the front mount.
The Alchemist
06-19-2012, 09:14 AM
Definitely do the front mount as well as Aster's 8-rib bracket setup and get the truck inlet too.
Just an FYI, 15psi on a stock shortblock isn't going to last long, no matter how conservative the tune.
01boydws6
06-19-2012, 11:30 AM
+1 for the front mount, 11psi on my stock bottom end resulted in 615/561..I was running out of fuel with the single pump, def. make sure your fuel system is up to the task.
chknhwk01
06-19-2012, 04:52 PM
will do, i can do this... d-1,front mount, truck,inlet,aster,s 8-rib bracket set up,12,pounds,an n20 75 shot,,on a 376,h,c, car weighs 3150,full ''spohn'' set up,410,s 325-50-15,drag radials, d0ne 6 speed, 17/8 new hookers, with the specal cones, thu a slp loud mouth specal drive shaff, 12 bolt,moser,with 30,spines, full race cluch,,and fly wheel, go fran go fran... can,t wait.. thanks again for the info....
Firehawk441
06-19-2012, 06:32 PM
JOE....You're looking into centrifugal superchargers?
This is the route I would suggest you going with using the 30mm cog drive.
http://www.yellowbullet.com/forum/showthread.php?t=372769
chknhwk01
06-19-2012, 07:30 PM
joe....you're looking into centrifugal superchargers?
This is the route i would suggest you going with using the 30mm cog drive.
yo,rick immmmmm,whats a 30mm cog drive???
Firehawk441
06-19-2012, 08:17 PM
30mm is the width of the belt.
Cog means the belt has "Teeth" as do the pullies.
Look at the pictures in the link I posted and you'll see what it looks like.
A cog belt will NOT slip like a serpentine can and will allow considerably less belt tension which will take more side load off the #1 main bearing.
The 30mm drive will also keep the supercharger in the same location that procharger puts it.
Give Dan Schoneck a call. He's the man who makes this drive. His website link is in his signature.
If you have any further questions just message me and I'll be glad to help.
chknhwk01
06-20-2012, 09:34 AM
If you have any further questions just message me and I'll be glad to help. u the man ''rick'' will do,thangs bro..
Frans96SS
06-20-2012, 09:45 AM
We just installed this bracket on a customers car... VERY nice piece but unless you are trying to make 1krwhp+ its not needed.
We made 940rwhp and 902 trq with the SDCE bracket before we switched. Its also 2k for just the bracket... You will have 8k+ in a procharger kit with that bracket.
The Alchemist
06-20-2012, 10:05 AM
Aster's bracket is pretty good as well since it uses a factory spring loaded tensioner which is easily sourced and replaceable. Lots of people have had good luck with it up to the F1 series blowers.
Firehawk441
06-20-2012, 04:14 PM
Anytime Joe.
firehawk 385
06-20-2012, 07:08 PM
Serpentine belts suck.
Dan Schoneck is the way to go.
chknhwk01
06-20-2012, 07:29 PM
serpentine belts suck.
Dan schoneck is the way to go.
yes sirrrr, thats who imm calling... We can do this!!!
chknhwk01
06-22-2012, 03:16 PM
gone with the big front mouth,,
chknhwk01
06-25-2012, 11:41 AM
Okay lets see, one D1 supercharger, one front truck mount intercooler and
asters eight rib set up bracket 12 pounds of boost and a 30 mm cog belt at Frans, in Delaware.. And super tune wow can't wait...and a 100 shot,maybe. and methal.
The Alchemist
06-25-2012, 01:07 PM
I'm not sure you can use Aster's bracket with a cog. Maybe I'm wrong, but all I've ever seen used is the 8-rib pulley.
chknhwk01
06-25-2012, 05:10 PM
will see,what he says... thankz for the info..:usa:
My84Z
06-25-2012, 06:24 PM
Cogs are a bad idea if the car is street driven. Asters and an 8 rib is the better choice.
chknhwk01
06-25-2012, 06:44 PM
good choice, thanks 84z...:nod:
Slowhawk
06-25-2012, 07:23 PM
D1, Aster bracket and custom front mount. Thats what we do and the whole setup is almost $1k cheaper than buying the twin intercooler procharger kit.
D1 with meth on a cam only car can safely make 650rwhp. We've gone 700+rwhp on a few (dynojet numbers) and they lasted for a good amount of time.
chknhwk01
06-25-2012, 10:11 PM
AND WITH HEADS, that I have, I like this package HOW much???
chknhwk01
06-26-2012, 08:58 PM
now that i got awe the parts i need, wicth i order,and got some good prices
ha, u guys put this kit to getter for me, and hats of for a great job,,
i should have awe my parts, with in too weeks.. i will keef u guys post it wend it awe gets he... thanks:D:usa:
we can do this........
chknhwk01
06-30-2012, 11:29 AM
PARTS ARE ON THE WAY ,ONE MORE WEEK,,,,:eyes::usa:
Slowhawk
06-30-2012, 12:20 PM
Should of contacted us directly. Had most of the parts in stock. Customer ordered a D1 but now wants to switch to an F1.
chknhwk01
06-30-2012, 03:36 PM
let me know,pm me, thangs,hawk. there nothing slow awbout u bro.....:usa::nod: happpppy
