Fuel Pressure Question
hey whats up guys, just a question about my fuel pressure. where should
it be set at for a 355 with 8.5;1 compression and a vortech v2 supercharger running at 5lbs..and what injectors should i have as well right now i have 42lb ones.
and how fast should the pressure bleed done with my aeromotive regulator its the one that goes right behind the rail....
thanks for any help you guys can give me.
I believe Aeromotive claims they want quick bleed down so there is no pressure left if you are working on the system. At least that was the excuse I saw when someone else was concerned about it.
What you really need to watch for is leaking externally and burning your car to the ground.
