Major problem. Head stud broken below deck. Please help!
Old 06-18-2012, 07:16 AM
Bafomet's Avatar
Default Major problem. Head stud broken below deck. Please help!
I was wrapping up a cam swap and valvetrain upgrade last night and had a new ARP head stud break off below the block when I was putting the driver's cylinder head back on. It snapped about an inch below the deck. I don't understand how or why it happened. I did the right torque sequence according to AllData and had all of the bolts and holes perfectly clean and used the suppplied thread lubricant. The only explanation I can come up with is a defective bolt.
Regardless, I'm screwed right now and I don't have any clue how to get this thing out of my block. Somebody please help me out here.
Old 06-18-2012, 07:23 AM
97badass's Avatar
Pull the head back off and center punch the bolt then use a smaller reverse drill bit if that don't work try a screw extractor in the hole you drilled.
00MaroonZ28's Avatar
Use one of the ez out that you can find at sears or a tool store. Use a drill. It's gonna be tough to get considering that it's torqued in there pretty good and a bit down in the hole. If that doesn't work, you'll have to take it to a machine shop and have them get it out.
Old 06-18-2012, 10:15 AM
lizeec's Avatar
He said its a stud. The studs are just supposed to be installed hand tight, I would try the above mentioned methods, it should have no pressure on it and should back right out.
Old 06-18-2012, 11:20 AM
tom falco's Avatar
Some times a sharp PICK can be used to remove it. If it is bottomed out or on the shoulder it is going to be mighty tough. Normally a stud will back out nicely because they are not bottomed out.
Old 06-18-2012, 12:17 PM
Bafomet's Avatar
Good news! I went at it with a left hand drill bit. It caught a bite and backed it out like butter. It definitely was a faulty part. You can tell by how it broke.
Old 06-18-2012, 04:36 PM
IRONFIST's Avatar
I broke a ARP head bolt and it was not fun to take out... not impossible but it would have been a lot easier to back out if the thing wasn't a hardened ARP bolt lol.
Glad you got it out, with mine I had to drill it out over a few evenings.
Old 06-18-2012, 04:49 PM
01ssreda4's Avatar
No, it was a faulty user. You don't use AllData torque specs. Try using ARPs torque specs next time. They are different.
Old 06-18-2012, 05:58 PM
KCS
Moderator
KCS's Avatar
LMFAO, you beat me to it!
Old 06-18-2012, 06:53 PM
iroczracer07's Avatar
At least he got it out, but yeah, you should definitely use ARP's torque specs and procedures..
Old 06-19-2012, 04:10 AM
vettenuts's Avatar
Curious as what the AllData value is that the stud was tightened to? Want to see how it compares to ARP's value with their lube.
Old 06-19-2012, 06:25 AM
tom falco's Avatar
Totally different procedure from factory specks TTY
FROM MY ALL-DATA
Notice: Refer to Fastener Notice in Service Precautions.
Tighten the cylinder head bolts.
9.1. Tighten the M11 cylinder head bolts (1-10) a first pass in sequence to 30 Nm (22 ft. lbs.) .
9.2. Tighten the M11 cylinder head bolts (1-10) a second pass in sequence to 90° using the J 36660-A.
9.3. Tighten the M11 cylinder head bolts (1-8) to 90° and the M11 cylinder head bolts (9 and 10) to 50° a final pass in sequence using J 36660-A.
9.4. Tighten the M11 cylinder head bolts (11-15) to 30 Nm (22 ft. lbs.) . Begin with the center bolt (11) and alternating side-to-side, work outward tightening all of the bolts.
Old 06-19-2012, 06:26 AM
Old Geezer's Avatar
Exclamation And, that...
Makes me wonder how many other studs are fubar, but not popped....
Old 06-19-2012, 10:56 AM
LS1MCSS's Avatar
None, the alldata torque spec's is the problem.
Old 06-19-2012, 02:22 PM
joecar's Avatar
If he used the alldata specs on the other studs then there is a good change they are also fubar;
the problem is the user's faulty selection of procedure/spec... the alldata procedure/spec is not at fault (how does it know if he's not using TTY bolts).
Old 06-19-2012, 03:06 PM
Grimes's Avatar
yeah i definitely would not trust the other studs anymore.
Old 06-19-2012, 03:11 PM
jasongantt's Avatar
congrats on the extraction.....and learn from this mistake.....ALWAYS USE ARP TORQUE SPECS ON THEIR PRODUCTS!
Old 06-19-2012, 06:33 PM
The_Bishop's Avatar
Also: If you torqued the other studs as if they were stock TTY bolts, they're trash now and hopefully you didn't damage anything else in the process.
Old 06-19-2012, 06:55 PM
tom falco's Avatar
Remove the heads can the studs and start over. You over yielded the studs. Once you do that the studs are JUNK.
Old 06-19-2012, 07:49 PM
Received 3,361 Likes on 2,079 Posts
Just out of curiosity, was this an aluminum, or iron block?
Quick Reply: Major problem. Head stud broken below deck. Please help!
