Generation IV Internal Engine - Why is the GM flat crank not used in production models?
LS1-450
06-18-2012, 08:51 AM
Why is it used in the C6R, but not in production engines?
The Alchemist
06-18-2012, 09:20 AM
Testing / development maybe?? Just like the C5R had the 427 and was used as the test bed for putting the LS7 into production in the C6. Who knows, the C7 might have a flat crank, smaller cube, higher revving motor as an option.
Wnts2Go10O
06-18-2012, 03:37 PM
the other thing is, the C6.R engine has 2 cylinders firing at a time iirc. but to answer your question... COST. the cranks they are using are NOT cheap and are tailor made for the application.
gm has already said the C7 will be 6.2L
LS1-450
06-19-2012, 03:17 AM
W/ the flat crank, would have to. Yah, cost is probably the reason. Maybe it will show up as an after market option somewhere.
From an OE standpoint a crank is a crank, it doesn't cost any more or less to make a 180* than any other crank...
It prob comes down to things like NVH, or even the tone of the exhaust
moge11
06-19-2012, 07:14 PM
simple..gotta leave something left for the years to come
Tainted
06-19-2012, 07:52 PM
You do know a flat crank just cant be simply swapped correct?
There was a thread a while back of an engine dyno flat crank lsx turning like 9000rpms
The Alchemist
06-19-2012, 09:27 PM
I think you need to match the cam as well and I'm not sure what else. Probably have to do something with moving around injector harnesses and coil packs as well since the valve events will be different.
Tainted
06-19-2012, 09:51 PM
I remeber there was a lot that was different. And not only the added complication but flat cranks arent as stable either.
Mike94ZLT1
06-20-2012, 08:05 AM
Why on earth would GM use it in the C6R if it wasn't as stable? Also, if it isn't as stable, why can they spin so high?
Tainted
06-20-2012, 09:35 AM
I cant explain all those details, look up the thread and there was lots of info about it and why its not stable, yet able to turn stupid rpms.
bww3588
06-20-2012, 10:46 AM
It's not stable at lower rpm's because of the harmonics. At higher rpm's, the vibrations come into balance naturally.
Remember the 4.3's with the balance shaft?
Higgs Boson
06-20-2012, 11:20 AM
street car vs race car
always compromises. it's cool at first but drive it every day and you begin to hate your car. that's why i am done with nutty street cars. give me something stock to drive to work and i'll get my kicks at the track.
wildcamaro
06-20-2012, 11:34 AM
I've read everywhere that C7 with be a 5.5l over head valve direct injected motor making around 420-430hp
wildcamaro
06-20-2012, 11:35 AM
Oh yea and what do you guys mean when saying "flat" crank...I haven't heard of that yet...
Tainted
06-20-2012, 12:16 PM
heres the thread with the flat crank engine dyno:
http://ls1tech.com/forums/multimedia-exchange/1460148-lingenfelter-flat-crank-ls-engine-dyno.html
lots of info in the thread explaining what it is etc.
SSCamaro99_3
06-20-2012, 01:27 PM
Been reading to many crappy magazines that are making the assumption that becasue the C6-R program is limited to 5.5L (by rule), that for some reason this is some testament to the street version.
LS1-450
06-20-2012, 06:04 PM
Think of it as the current "stock" LS crank looks like a + when viewed from either end where a "flat" crank would look like a - . Stock crank, bearing seats Are located @ 90*. Flat crank, bearing seats are *180.
wildcamaro
06-21-2012, 12:18 PM
Oh ok I got you that sounds pretty cool...I love seeing the evolution of GM ohv engines!
bww3588
06-21-2012, 12:28 PM
Looks like a 4cylinder crank, except there are 2 rods on each journal, and 4 slugs at tdc at the same time and 2 firing at the same time.
