New LS1 Owners - Newbie Tech - LS1 Spark Plug Change
View Full Version : LS1 Spark Plug Change
LIQUIDZ28
06-18-2012, 09:21 AM
#1 remove "air" from passenger side exhaust manifold and move it aside carefull not to dmg the gasket.
#2 remove coil pack assembly on 98 models the packs mount seperately newer than that the whole pack system sits on a rail.
#3 replace all plugs on passenger side and replace
#4 put everything back on, note that on 98 models the packs and harness can be installed backwards so pay attention to the markings on the harness.
#5 driver side remove "air" tube and set it aside carefull not to dmg the gasket.
#6 remove all plug wires
#7 remove and replace plugs
#8 reinstall "air" tube
done.
set aside at least 4-6 hours for this job and make sure the car is cold, or you'll be sorry.
TyCZ28
06-18-2012, 09:38 AM
also note that the passenger rear plug or plugs is easier to grab from the bottom of the engine if you still have A/C
RPM WS6
06-18-2012, 11:05 AM
No need to be careful of the AIR gaskets, they are cheap so just replace them IMO.
No need to remove the coils on a '98, it's more work then it's worth and you have enough room to get at the plugs with them still in place. On a '99+, the rail really needs to come off if you want to get at #8 from the top.
Not sure why people think it's easier from the bottom. IMO it is not. Exhaust is different on '98-99 vs. '00+, so this may account for the different opinions on this.
BlackScreaminMachine
06-18-2012, 11:51 AM
On my 2002, its always easier to remove the coil rail and like said I use various sockets, extension and wrenches depending on which cyl I am on and AIR gaskets are cheap.
2win_SS
06-18-2012, 07:11 PM
done.
^^^ I swap out my plugs without having to remove AIR or Coils... I also believe it's easy to take the back passenger plugs out from the bottom.
98z8uup
06-19-2012, 08:21 AM
I also remove from the bottom of the car.
