LS4 Performance - Gxp won't run
jsmith309
06-18-2012, 12:00 PM
2006 grand prix GXP won't run!! I have fuel pressure! It just won't fire when cranking! My fiance was driving it and it just cut off on her. I was told it should be the crankshaft sensor. Any other suggestions??
I bought The car may 20th.
Since then ive replaced the alternator, tensioner pulley assembly, serpentine belt. The a/c went out last weekend and now this.
JessmoMonteSS
06-18-2012, 01:35 PM
It sounds similar to symptoms of a bad crankshaft sensor. Was there a check engine light for it? Does it start when cold? The ones I've come across usually will start when the vehicle is cold but once it warms up it will die and when you try to start it back up again, it just cranks and cranks.
jsmith309
06-18-2012, 03:09 PM
Just let it sit overnight and tried to recrank it. No fire
JessmoMonteSS
06-18-2012, 04:02 PM
Any check engine lights?
BlackImpSS
06-18-2012, 04:54 PM
How many miles? Pull a front plug and make sure your getting spark too.
jsmith309
06-18-2012, 11:21 PM
Not getting spark. My only code is p0118
Ill_Born_ss
06-19-2012, 06:06 AM
ECT (engine coolant sensor) has failed in the over temp position.... the nannies are protecting you! Replace the sensor with a GM original. You may get it to start by disconnecting the sensor, but other things will not function properly until it is fixed properly.
MillerMonteSS
06-19-2012, 11:44 AM
This happened to me in my Monte. When I put the key in the 'On' position, your temp gauge went all the way up and the fuel gauge went all the way down. I used a handheld scanner to get me off the side of the road by resetting the codes after I was SURE I wasn't overheating. After I replaced the sensor, it was good to go.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
