General Maintenance & Repairs - Transmission Mount Twist
View Full Version : Transmission Mount Twist
RedVertTA
06-18-2012, 02:12 PM
Title says it. After replacing my transmission mount with a factory style replacement and torquing it down I noticed some twist in the rubber mount, as it the bottom section is trying to twist clockwise. See pics below:
http://i392.photobucket.com/albums/pp8/BradZ01/DSC03347.jpg
http://i392.photobucket.com/albums/pp8/BradZ01/DSC03349.jpg
The mount was bolted to the tail shaft and torqued to spec at 18 ft lbs and the other end of the mount was bolted to the x member and torqued to spec at 77 ft lbs.
Is this normal?
nomasterase
06-19-2012, 04:38 PM
what condition are your motor mounts in? maybe theyre worn enough to allow the engine and trans to be twisted enough to cause that
RedVertTA
06-21-2012, 08:47 AM
They are new, so is the transmission mount.
mjs1012
06-21-2012, 09:06 AM
If the motor mounts are poly you could have put one in upside down. I had the same exact issue and had to flip it over.
RedVertTA
06-21-2012, 09:43 PM
Its not a poly mount, its rubber.
99Bluz28
06-23-2012, 05:17 PM
It does that a little even with poly trans mounts. You could use a small pry-bar to hold it in place when you tighten it down.
RedVertTA
06-24-2012, 09:48 PM
Will the twist actually hurt anything though? Or is it ok to leave it the way it is?
mjs1012
06-25-2012, 11:13 AM
It might cause the tranny mount to rip prematurely due to the stress of it not being centered and forced into place.
