Fueling & Injection - Upgrading Racetronix Kit
What would be the best way to upgrade from the racetronix hotwire kit and racetronix fuel pump to a dual pump? I am guessing follow the sticky on adding dual pumps and run additional wire to power a second pump then add a walbro fuel pump to the setup?
would running a walboro and racetronix pump together pose any issues?
ZL1Killa
06-19-2012, 07:16 PM
I'm running an external pump...Lonnies sells a kit and NastyN8 and Heintz Racing
what i'm after is to retain the racetronix fuel pump and hot wire kit. then add a second pump inline to help pump more fuel. What would be a good way to go? i was thinking it would be easy to put it where the stock fuel filter is, then possibly add a regulator at the fuel rail as people say this helps respond quicker on high fuel demands.
would this work and how much would i really gain with a setup like this? Also what would be a good external pump to add inline? i would make it boost activated most likely.
ZL1Killa
06-25-2012, 08:29 PM
I would call and speak with one of them to get your setup right.
I8UR4RD
06-25-2012, 11:13 PM
step 1.
call lonnie
step 2
get money
step 3
send money and fuel bucket to lonnie
step 4
re install
:google:
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
