Rowe929
06-18-2012, 05:26 PM
This is a 1998 pewter colored c5 corvette, I purchased the car 2 years ago. Withing the two years I have changed all the fluids with synthetic fluids(trans, engine, differential, brakes and power steering) last year I rebuilt the top end of the engine just because, I upgraded the stock heads to ls6 core heads that were cnc ported meaning making a smaller chambersize for more compression and bigger valves and new springs, retainers valves.ext I put ls6 lifters, aftermarket push rods, bigger fuel injectors, a nhra approved light weight under drive crank pulley, the car has a 92mm fast intake manifold with a bigger mass airflow sensor, and bigger throttle body(match intake size) I used gm Performance head gaskets.. I went with a comp custom grind camshaft, I also put a lower temp thermostats in the car so it runs colder it's a 170 degree thermostats, I Put a high pressure oil pump in the car so it has better oil flow, and I upgraded the old timing chain to a double rolling timing chain, also the car has long tube headers and 3" inch back slp loudmouth exhaust... I had the stock rims powdercoated gloss black a few weeks ago and replaced the 2 front tires and got the car alignment done after, as far as brakes go I have drilled and slotted rotors with hawk pads all around, and stereo is a touch screen DVD Bluetooth radio, with a custom box and amp rack, the car was dynoed at 450whp so it has over 500 engine hp, i also put a msd high torch starter in the car..there is more done to the car but can't think of it all, nothing was done cheap or rigged, all work was done correctly, car passed emissions and is very reliable. A/c blows cold. This car is my baby i wax it once a month and buffed and polished it a few weeks ago...if your intrested please feel free to send me a text message phone call or email 708 997 0697 email is rowe87@sbcglobal.net thanks for looking
