Carbureted LSX forum - holley dual carb intake
slinginrods
06-18-2012, 10:07 PM
any body use one?if so pros and cons.or any opinions on using one.
Pop N Wood
06-19-2012, 05:13 AM
Haven't seen anyone who has. Someone posted a car mag article on here within the last month or so that showed that manifold picking up significant mid range torque on a single plane while not giving up anything at high RPM. Motor was a bit of a bastard, a 5.3 with a long stroke and sort of crappy heads.
Give it a try then come back and tell us what it does.
ZONES89RS
06-19-2012, 06:39 AM
Try it, if you don't like, sell it here.
slinginrods
06-19-2012, 01:46 PM
thanks,i have a 2x4 intake for a sbc with two 500 cfm edelbrock carbs ,i may pick one of these up just to try it out .
boogiewonderland
06-25-2012, 10:35 AM
It should work fine with a boost in torque based on the extra fuel volume and better air flow. stroke will give the extra room for that fuel and air to be drawn into cylinder.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
